Old 06-05-2003, 01:39 PM
Todd Hedges's Avatar
Cobra Make, Engine: ERA 427SC w/428 & Richmond 5-speed Car 611.
Default Flying Meatballs!
Darn it!
Lost two of 4 meatballs.
Not even 100 miles on them and 50% are gone!
Used Zymol wax, and they didn't stick.
what a waste.
I liked the way they looked.
Might have to have some painted on.
static cling my a$$.
...."they say I'm crazy, but it takes all of my time."
Old 06-05-2003, 01:46 PM
Roscoe's Avatar
Todd,
How did you apply them?
Roscoe
Roscoe
Old 06-05-2003, 01:50 PM
Stuck them on a clean dry surface.
No soap, residue, oil, armour-all, etc.
Just clean, dry clear coat.
Old 06-05-2003, 01:51 PM
Default I bet...
if you simply used some duct tape around the perimeter of the meat ball it would stay.
Old 06-05-2003, 02:02 PM
My first guess was that I used the wrong kind of sause.
I pressed the meatball against the paint and most of the sause squeezed out and ran down the side of the car.
Maybe I can tie them on with a linguine or ziti chain.
Old 06-05-2003, 02:25 PM
rdorman's Avatar
Renegade Nuns on Wheels
Default Wet meatballs anyone?
Wet the area down with water, put on the meat ball and squeegee out the excess and let dry over night. Mine have never flew off!
OhioCobraClub.com
LondonCobraShow.com
Old 06-05-2003, 02:31 PM
Roscoe's Avatar
Todd,
Rick is right. You have to use some type of liquid. Soapy water is good, I use windex. Squeege out the bubbles and give it some time to setup. I drove to Carlisle in an hour and half downpour at 60mph and did not lose any of the 4 meatballs.
Roscoe
Roscoe
Ron61's Avatar
Smile
Cracker,
That would be the 200 mile per hour duct tape, right !!
The way Rick did it is the way we put the stripes and stuff on a friends Cuda and they have never peeled or even acted as if they want to come off. And that was about 3 years ago.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 06-05-2003, 02:35 PM
rdorman's Avatar
Default Windex!
I will have to give windex a try. Clean and install in one step! Water works fine but I can see where windex might be better. I seem to recall some one using one of those 'speed shine' products as well but have never tried it since water has always worked so well.
Use a squeegee that is not to hard nor has any sharp edges. Like the ones you use on glass and be sure that everything is clean/dust free. Over night to dry is best.
OhioCobraClub.com
LondonCobraShow.com
Old 06-05-2003, 03:45 PM
mikiec's Avatar
Remember meatballs are static cling....If your wax/polish is low static or no static the meat balls will not stick. I just changed to Zaino and have shelved my meatballs.
Old 06-05-2003, 04:13 PM
Cobra Make, Engine: SPF #1019
Thumbs up Works for me!!!
I've got at least a half dozen coats of Zaino Z2 on my SPF, and my meatballs stick - and stick well. I've done 140 on the front straight-away at T-Hill many times without a single edge of my static-cling meatballs even thinking about starting to peel off.
First I wipe down the side with Z6 to be sure it's clean of dust. Then I squirt liberally a mixture of 1/2 capful of Z7 car wash in a 16oz squirt bottle. I then peel the meatball off of the refrigerator (best place to store them) and apply it to side. If needed I squirt some more under the edges to ensure that the meatball is really slippery against the side of the car. This allows me to position it exactly where I want it. I then grab my roller squeegy and start rolling out the excess liquid and air bubbles, starting from the center and working towards the edge. I go all the way around twice to be sure. Then I wipe off the excess liquid with a dry polishing towel. Then do the other side. I let the car sit for at least 24 hours before driving it.
I have repeated this process for the past few years, and even applied my meatballs to my Mustang to go OT'ing at LSIR (noise limits prevent running my SPF there).
The key is using a good soap based solution, rolling out all of the bubbles and liquid, and letting it setup. Then storing them properly.
Hope this helps!
Randy R...
Old 06-05-2003, 04:17 PM
mikiec's Avatar
Thanks, Randy...
Zaino told me they would not stick.
I can now use them again.
Old 06-05-2003, 08:43 PM
ls1ac's Avatar
The roller randy talked about really helps.
Soft rubber like used for printing, about 3 to 4 inches wide.
Get it at a craft shop.
HAVING TOO MUCH FUN
Scott
