07-31-2003, 04:34 AM
Banned
How far apart should the stripes?
I've heard 1 inch and I have heard 3/4 inch. .
Also, how wide should they be, if not tappered?
07-31-2003, 05:19 AM
Cobra Make, Engine: A&C 351W, C4
Stripes
Hi RS,
Striping is purely subjective. Some guys go with the taper and some don't. I have an A&C and their assembly mount shows no taper and they show a one inch spacing between the stripes that are 7" wide. If you go to ERA's website they show stripe specs listing only a 3/4 " spacing between the stripes that they show (and provide dimensions) as tapered.
There is also the option of adding the border stripes. Usually these are spaced 1/4" out from the broad stripes and they are usually 1/4" wide.
Look through the members galleries at some of the guys cars and that should give you some ideas to help you decide. Striping, basically comes down to personal preference.
07-31-2003, 07:40 AM
Ut
Most originals we have seen have a 1" gap. We use a 1" gap on all of our stripes.
07-31-2003, 08:16 AM
If you want accurate information on the placement of stripes, I recommend you go to ERA website.
Here is the link showing how the stripes should be laid out.
http://www.erareplicas.com/427man/stripes/index.htm
TURK
OBAMA IN in 2012
07-31-2003, 05:11 PM
Banned
David Kirkham,
What should the stripes widths be?
Do you do yours tappered or straight?
What were the originals?
Thanks!
08-01-2003, 12:38 PM
Mine were painted by AC to original specs with seven and a quarter inch stripes with a 1 inch gap and no taper. Many people say that they should be tapered but I would be amazed if the painters of the original race cars would have bothered to do this.
08-01-2003, 03:04 PM
Stripes
Was there 1/4 inch border stripes?
08-02-2003, 12:44 AM
Tony. Not on mine or any of the original factory cars that I have seen.
08-04-2003, 04:03 PM
co
Cobra Make, Engine: 1984 S-V WITH A 5Liter Eight stack EFI
SPEAKING OF STRIPES
Does anyone know what the specs for the cross hood stripes are?
I understand the racing teams originals had them located across the hood!
Johnny
08-19-2003, 09:48 AM
UK
Cobra Make, Engine: Hawk 289FiA with Le Mans hardtop. AC CS(X)2131,289 (my father owned it from `67-`73)
The Willment Racing team used the stripe layout of thin-thick-thin, although I don`t know the exact dimensions. Maybe Fritz( COB289) or someone from Hawk can tell you, as their 39 PH version was modelled directly from the real one.(see below)
For a better look, click here.
You could probably work it out from the size of the numbers on the plate?(Standard UK regulation size)
"If I plagiarize, it's only because I like someone else's idea better than mine and I want credit for it."- Anna Sato-Williams.
"If I plagiarize, it's only because I like someone else's idea better than mine and I want credit for it."- nikbj68
08-19-2003, 12:49 PM
UK
