08-20-2003, 07:55 AM
VA
STEVE - - RIGHT ON - -
THERE ARE TWO TYPES OF ANY MACHINE - -
** THOSE THAT HAVE FAILED, AND,
** THOSE THAT ARE GOING TO FAIL.
Y'ALL HAVE A REALLY GREAT DAY,
BLACKJACK
08-20-2003, 07:59 AM
Ouch Ouch Hot Sand
Is ther a website for the Auto-Lifter??
I tried a Google search and came up with all kind of dumpster and garbage can lifts?????
08-20-2003, 08:16 AM
Tx
Cobra Make, Engine: CSX 4039 427 FE 1966- SOLD
Originally posted by Dan Semko
Blackjack,
You might want to call Fruit of the Loom. They might want to use your experience for commercial material.
Glad your guardian angel was on duty.
On the inquisitive side: why didn't you have your ex under the car? If you need more test dummies to prove your point on the defective pulleys, I'm sure many of us will gladly volunteer our ex's.
 LMAO
My carbon footprint is bigger than your carbon footprint.
08-20-2003, 08:25 AM
Cal
When you put a car on a lift, the hydraulics lift the car, then you slowly lower it to the mechanical stops before going under it. Don't rely on hydraulic pressure with a jack or a lift to keep several tons of steel in the air above your head.
08-20-2003, 08:55 AM
Cobra Make, Engine: KMP/427co
Link
08-20-2003, 09:47 AM
Blackjack,
Very glad to hear you weren't killed, didn't lose an eye, or otherwise seriously hurt. You're doing a valuable service by letting us know. The company should be doing everything possible to get the word out, period.
TT
08-21-2003, 10:05 AM
Jack, glad to hear you're okay. I have a 9,000-pound Autolifters model in my garage and I'll be checking it tonight...
Actually, they do make jackstands that tall, or close to it. A few weeks ago I bought a pair from Napa. They are screw jacks, made specifically for use under lifts. They are about five feet tall and have a screw-out "pedestal" that can be raised another couple of feet or so (I'm a little vague on the details as I haven't used them yet). Each one is rated at 1,500 pounds. I intend to use them to help support exhaust systems, transmissions, etc. when I'm working under the car, but if you were really concerned about lift safety, one of those under each corner of the car would be good insurance. They cost me about $70 each, if I recall correctly.
I've had my lift working for about ten months and am still paranoid about getting under a car on it, even though most of the stuff I put on it doesn't come anywhere near its rated capacity. As Mr. Fixit suggests, I always lower it down onto the locks before getting underneath the car. I don't think you can be too safe when you're on the wrong side of two tons--
08-21-2003, 12:53 PM
VA
SNAKEEYES,
I BELIEVE THE JACKSTANDS YOU ARE REFERRING TO ARE "TRANMISSION JACKS" DESIGNED TO DO EXACTLY WHAT YOU PLAN TO USE THEM FOR.
I HAVE TWO OF THEM AS WELL BUT I SURE WOULDN'T TRUST THEM TO HOLD A LIFTER UP IF THE SAFETY DOGS FAILED.
ONE OF THE BEST FEATURES OF THE "AUTOLIFTER" IS THAT IT'S NEARLY IMPOSSIBLE TO HAVE THE DOGS FAIL. I SAY "NEARLY" IMPOSSIBLE BECAUSE AFTER 23,000 + HOURS FLYING I'VE SEEN EVERYTHING FAIL - - AT LEAST ONCE!!
BLACKJACK
