08-20-2003, 04:53 PM
A close call and a big-time WARNING!
Hi all,
Cliff & I had a close call Friday in turn 3 at Summit Point during the fourth of four track sessions..
We went off the road suddenly and flipped over. Cliff had a sore knee for two days and I broke, er, pulverized a wrist.
The potential culprit is the right rear lower suspension arm of the Jag suspension.
More info is at
CACC FATT thread
and some pics start at the bottom of the gallery at
CACC gallery wtih INDY's pics
There is more detail under other threads.
All I can say is phew!
A full exam of the car is scheduled within two weeks, so the theory about the wishbone failure is just that - a theory. Nonetheless, check yours - make sure no welding was done! Mine seemed to have a clean break near the hub end: more details in a couple of weeks.
Regards - Tom
08-20-2003, 06:25 PM
Hoosier Gashole Emeritus
IN
Tom,
Glad to hear and see that you personally sustained minor injuries. The glass can be repaired and the weather will be a constant reminder of the wrist injury BUT you're alive and reasonably unscathed.
DDS/The First Edition
"In debates on ethically contentious issues, it is never wise nor polite to deride or belittle another person's delusion."
08-20-2003, 06:31 PM
Thanks for the heads up Tom! I don't know you but am sure glad to see a fellow Cobra brother made it through as well as you did. It looks as though the roll bars did the job. Are they the stock units that come with the car or did you upgrade them to pure race units? Best wishes to a quick and comfy recovery!
08-20-2003, 06:34 PM
Mi
Tom,
Damn fella! You do look better standing up!
Just an offer, not a solicitation, but if you want, I WILL make room in our shop for your sick snake. We'll take care of it, you take care of the wrist
DV... Thank goodness for a well built car with TWO roll bars!
08-20-2003, 06:37 PM
NC
Cobra Make, Engine: Factory 5 mk4 445 FE
Sorry about your bruises. Man, it could have been so much worse.. Just thinking back about the "bitten by the snake" video.. didn't some one loose a rearend in that and wreck at some track.. wonder if it was the same kind of thing....
08-20-2003, 08:12 PM
Whoa! A sobbering tale. I'm listening. I'm also thinking about how the "flip top" got into car 198's oil at the Historics.
Now matter how good a driver you are, stuff happens you CANNOT control.
I'm SO glad you guys are all right, it could have been way different.
Ernie
08-20-2003, 08:32 PM
NJ
Wow
Glad you are OK. I am interested to find what the problem was. On the real car the rear upright were known to fail. That's why Kirkham put so much R&D into theirs.
08-20-2003, 08:37 PM
Tom,
From one Tom to another, very glad that things didn't turn out considerably worse. You need to get the reinforced control arms, billet or gusseted--I was happy with the CWI stuff, but there are probably other vendors too.
Take care of yourself,
Tom T.
08-20-2003, 08:45 PM
Tom,
Did the car have a full width roll bar, a single hoop, or double hoops?
Glad y'all are not injured any worse than you are.
08-20-2003, 09:39 PM
Tom , sorry the cobra got a little bent up, but real glad to hear you are OK.
The rewelded (shortened ) sedan wishbones are notorious for this failure, anyone running Jag IRS should inspect and replace or reinforce a rewelded lower control arm.
the factory weld on the E-type is very fine and would be tough to confuse with a rewelded sedan unit.
again Tom, heres to a total recovery
KK
08-21-2003, 04:40 AM
Hi Tony & Dave,
The roll bars are the stainless Everett Morrison dual units that came with the kit. I like their appearance better than the full width unit, and they have one extra upright.
Hello DV,
Thanks for the offer! I called Fred Gimbel last weekend - he had already heard and is making room for the car by the end of next week!
Hello Tom,
I tried Mike at CWI yesterday and left a message. If he has some arms and axles, that's most likely what I'll do.
Hi KK,
The arms were supposed to be stock 3.8s/420 arms which are the correct length from Jag. That's the first thing we'll check.
Regards to all and
GET SOME ARM RESTRAINTS?
Tom
08-21-2003, 05:08 AM
Glad your ok. I was just discussing with my cobra builder tonight how we were going to strengthen the lower control arms and the drive shafts on the jag suspension in my car. I would be interested in the results when you find out what went bang. Get well quick.
Andy.
All torque, no traction!
Anything is possible (if you can justify throwing bucket loads of money at it!).
08-21-2003, 06:48 AM
Ut
Tom,
Bummer, hope you get better soon.
Sadly, this is not the first time I have heard about this. This problem has been going on for years. Any ideas on where we could post some of these potential problems to avoid even more serious injuries to our friends and Fellow Car Nuts?
Steve,
We forge our rear uprights out of 7075 T-6 aluminum. Probably the last part on the car to break! I just don't trust castings--especially ones that are made in low quantities where there is not enough time or money to get it right. Casting is still a "Black Art" and no matter what anyone says--I don't like using them. Ford casts millions of things--and pays millions of dollars to the foundry to get it right.
Currently, there are only two castings in our car. The aluminum differential housing (we have made hundreds of them now), and the rotors. (Wilwood has made thousands upon thousands of them.)
Nevertheless, I think all of this mess was caused by a welded control arm. I hate welds too. (You should see some of the original welded control arms! Oh man are they scary!) That is why we are now billeting most of our control arms. (Some simply can't be billeted because of their construction/geometry constraints--but they are TIG welded by a CERTIFIED aircraft welder--with FORGED ends.)
08-21-2003, 07:59 AM
Pa
Cobra Make, Engine: FFR2479K, 351W yellow/black stripes
Tom,
Get well soon. As you are a CACC member, I am guessing that part of your stengthening rehab for that wrist will be to lift 12oz cans.
Serioulsy, get well soon. You need to get ready for next season. I'm trying to work with ClubCranky to plan some big open track events for next year.
Steve
www.midatlanticcobras.com
No, it ain't "real", but it's real fast....
Some people choose to rattle their windows with stereos and speakers... I choose to rattle windows with my right foot.
08-21-2003, 08:19 AM
Oh
Cobra Make, Engine: Unique 289FIA / SA 351W / a truly glorious machine
Where should I be looking for the welds on the Jag suspension???
Hope you both recover to 100%. Hopefully the wrist won't be a constant reminder....
Best of luck and I'll be looking for the posting after the investigation into the cause....
regards,
al
08-21-2003, 08:20 AM
OK
Tom,
First of all I am glad your injuries were minor.
I have looked at your pictures and I am amassed at how little damage your Cobra sustained. I know that a lot of the damage isn't avalilable for us to see but the damage to the glass windshield and some minor fiberglass damage seems to be all there is to repair except for the rearend configuration.
Good luck with your recovery.
Clois
"Let's roll"
"Be part of Something Good
08-21-2003, 08:24 AM
WA
Glad to hear you survived, "Indy" !
Best wishes for a speedy recovery. This incident will set back your "guinea pig" status  (EFI test subject) for the rest of us that are about to install a Holley system. It is interesting to note that the 36 lb injectors do work after all, on this size/powered motor.
The troubles with various basic/donor IRS systems are why I went with the 9 inch straight axle rear system (and the West coast) it seems bulletproof. If I do change to a custom IRS later, it will be CWI.. I have inspected a CWI 9 inch center IRS install, firsthand at a local rod and custom shop...it at least LOOKS impressive!
Try taking lots of MSM (joint rebuilding sulpher) as an aid in healing..You can get it at Costco Ginseng will help too.
08-21-2003, 08:38 AM
Casaleenie,
the lower control arms consist of two forged ends (wishbone /differential side and hub side) connected with a piece of heavy tube. The tube is welded at the forgings with a very fine ,smooth bead maybe 3/16 wide and a total raise of 1/8 at the most. very obviously a factory job.
KK
