09-02-2003, 01:36 PM
NJ
Jerry,
A friend of mine just got one from TriStates and it looks really good. He also dropped the rear a bit. Don't exactly know what that is but it is supposed to round the rear a bit more than it is.
Roscoe
Roscoe
09-02-2003, 01:49 PM
My fiberglass bath tub holds water better than your aluminum bath tub!
09-02-2003, 02:06 PM
Ron,
How many hours do YOU have in your car so far?
TURK
Seriously!
OBAMA IN in 2012
09-02-2003, 02:31 PM
SC
Want to bet.....Just look at my avitar (it was in an FFR). You would be surprised just how much water was in the car that day........
Bill S.
PS; Of course my Contemporary has a convertible top, so I have yet to fill it with water to see just how much it can actually hold in comparison.........
09-02-2003, 02:38 PM
Cobra Make, Engine: BDR 930, 427 Windsor T56
Originally posted by RACERAL
one thing I see about all the cars is..... ffr gives you the chance to build a nice car or a crappy car..... its up to you...
Bingo!!
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
09-02-2003, 06:08 PM
Banned
N.J
Davidg?: The FFR frame is better than the original? How so? Hmmm.
I think RACERAL said it best. FFR can be a great car or a poorly executed car. Depends on the builder and parts used.
09-02-2003, 07:08 PM
Can I say what I REALLY think without causing a big hoop la? Ah,,,maybe not, what the heck, here it comes anyway!
I don't like the trunk, the pointy thing the center light sits on. Other cars have a similiar design, Mid States comes to mind, even more! Maybe it's more "original" in appearance that way? What ever, I don't care for it myself.
And the way the lower portion of the rear fenders sit a little high, exposing the bottom of the gas tank, I don't like that either. And I worry about how "stout" that glass body is (compared to say a Classic Roadster).
Andy Rooney,,,,uh,,,,I mean
Ernie
09-03-2003, 05:36 AM
NJ
Roscoe
09-03-2003, 06:16 AM
Va
Cobra Make, Engine: FFR2573 & FFR 3265CP
Real1,
Nearly all the currently produced replica's have a better frame than the original.
The materials alone are nearly twice as strong as those produced in the 60's.
Not to mention the current building/Welding techniques.
Brad
Brad Drummond
FFR 2573
FFR 3265CP
http://www.drummondmotorsport.com
09-03-2003, 06:29 AM
Evan...Brad is correct.
Hmmm,...even yours is different and better than the original...using thicker main tubes.
09-03-2003, 10:22 AM
Banned
N.J
Ok. But what constitutes better? Originality and accuracy of design? Rigidity? Weight?
I've heard that a frame that is too rigid may not be as good as a frame that has some flex. Is this true.
I've never heard of an original frame that failed under racing conditions.
The originals did just fine in competition thank you.
09-03-2003, 10:35 AM
I understand the original frames were subject to "sag". Over what period of time and the specifics I don't know!
As far as racing goes it wouldn't be a stretch to assume that "over time" the 289 FIA cars (for instance) did indeed require some "frame work" of some kind.
The 427 frame was bigger. For what purpose? More rigidity because there was more weight on the car? More "torsional" stress with the big block? Or to overcome the inherent "sag" problem? Maybe all of the above, I don't know.
The statement made here about FFR frames being stronger than original to me is like....."So what else is new". Stronger than say an ERA, SPF, Classic Roadster, SAI or Kirkham car? I doubt that. Most likely ALL the re-creations have stronger frames than the "originals" had. Which is NOT to say the "originals" were weak, but could have been better.
Ernie
09-03-2003, 10:38 AM
Evan....what can I say...you're hopeless.
I started a big long tech answer, but...I stopped... it wasn't worth it.
"I've never heard of an original frame that failed under racing conditions."
...what structural/chassis failures HAVE you heard of on 'originals'?
..so did Fiats. What does that prove? So do ALL replicas that finish in the money at track events.
Suffice it to say that the CHANGES that were made to YOUR frame....that makes it DIFFERENT than the originals...make it BETTER.
Your argument has no purpose and no finish line.
09-03-2003, 12:52 PM
CO
As stated earlier...the FFR is a great car if built by the right person with the right parts. That said, I think most here believe that if one is to invest the time and money required to make a FFR a great car, they MAY want to consider other options.
IMHO it is an issue that you can have a trick FFR built to perfection while the guy next to you can have a donor FFR built to "garage" specs and you both own a FFR. This would bother me, but just because it bothers me doesn't make me right (I don't even own a Cobra so who I am to say).
The guys posting here who own FFR products have lots of time and money invested in their cars and have every reason to be proud of them ........just like Evan!
'It's not getting any smarter out there. You have to come to terms with stupidity and make it work for you.' -- Frank Zappa
09-03-2003, 12:56 PM
HIQ,
Are you saying that ......Evan.... has a right to be proud of his Factory Five ?
09-03-2003, 01:26 PM
Banned
N.J
Hopeless?  Yup.
Are the chasis of today stronger than the original Cobra chasis. Some I'm sure are.
FFR Spec Racer is a neat car. Maybe one day when I have some more spare time.
09-03-2003, 02:38 PM
Renegade Nuns on Wheels
Oh
Ladder frames
Ladder style frames are weak by design. Heavier material helps but will never overcome the design. Triangulation, stressed skin, cages, etc all help a bad design. Some are better then others. Not one of us will ever know for sure which one is best
Frames should not flex! But I am sure there is a point of diminishing return. I would think that some of the replica frames rival or best the originals, some don't. I would think that the new cars from Shelby have stiffer frames than the originals. Point is, you can make some good guesses looking at a frame but that is all they are, guesses.
09-03-2003, 02:43 PM
CO
FFR spec racer is a VERY cool car! To me it is their best product in that it is really the best of class. Their "standard" product on the other hand competes in a very COMPETITIVE field.
FFR Cobras can be NICE or they can be CHEAP, but I have never seen a NICE CHEAP FFR. If you buy one because you like the frame or just think it best fits you needs, ENJOY. But don't buy the kit based on price.
09-03-2003, 03:34 PM
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
now what do you think?
rem,
don't worry about the frame on a FFR, it's about 2.X time more rigid in the cross flex arena that the current pick up you might drive. never have seen a frame on a CSX3XXX car fail, only the drivers. as to the "sag" comment, don't think so. That said....IT IS NOT A OFF ROAD CHASSIS, if one looks for that type of strength, get a HUMMER!
grumpy
10-24-2003, 01:12 PM
ct
Cobra Make, Engine: FFR MK III
Originally posted by decooney
Ozona,
this is another great point about the FFR. It seems you are not held to a specific build or type that hurts the value too much on an FFR. People build them with 302s, 351, SuperChargers, 4.6, V-6 Turbos...FEs, and various wheel and tire combinations with custom adds that make them sort of personalized - which is kind of cool.
One of the more fun and interesting things I look for now is who is trying and doing something different!
I just ordered an FFR kit the other day. I shopped ERA and a couple others. All make wonderful products. The deciding factor for me was the fact that I have a 500 HP Pontiac motor sitting in my garage. Nobody in their right mind would put that in one of the more expensive kits. I also wanted to do all of my own fabrication and customization. I am going the non-donor route, and using it as an opportunity to study every little piece of the car and research all of my options. When I am done, I will have exactly the car I want and have the pride associated with building it from the ground up.
I am sure I will get some interesting looks and comments from "purists" when I open my hood, or they notice the 315's on 18" wheels....... Hopefully, I will not be upset by peoples comments. Bottom line is figure out what you want to do with it, figure out if resale value and time expended is worth much to you, and figure out who you are trying to impress. Are you trying to have fun, or are you trying to impress people. If you have a cobra replica, 99% of the people you meet will be impressed no matter which one you go with or how crazy you get.
