Old 08-23-2003, 06:43 PM
Bulld0g's Avatar
Default Fan not working some help
I was out driving today when I notice that the temp was getting pretty hot so I popped the hood and the fans were off I checked the fuses checked the circuit breaker replaced them and the fans still are not working any ideas please help tomarrow is going to be very nice out I want to be out driving not bent over and scratching my head looking to find the problem
bulldog
Old 08-23-2003, 07:10 PM
Rick Parker's Avatar
Check the fan swith that fits in the cooling system and trips the relay.
Old 08-23-2003, 07:12 PM
Bulld0g's Avatar
I'm kind'a new at this were would I look for the switch
Old 08-23-2003, 07:30 PM
It could be screwed into a fitting in a radiator tank, or into the intake manifold near the top radiator hose/thermostat housing. Or it could be in the lower radiador hose. Follow the wires from the fan to the relay(?) and then see where the other wires that attach to the relay go, they should be attached to the thermo fan switch in question. Ocasionally there is no thermo fan switch at all and the fan is wired direct, ie: to be on when the key is switched on.
Old 08-23-2003, 07:32 PM
Bulld0g's Avatar
Bingo that how my fan was working turn the key and you could hear it were do I go from there
Old 08-23-2003, 07:46 PM
With the key on check for 12 volts at the fan, If you have voltage you may have a bad motor. If no voltage go back to power source/fuse. Check for power there. Check fuse, Process of elimination. If you have power at the fuse follow circuit to the fan continuing to check for voltage.
Old 08-23-2003, 07:49 PM
Bulld0g's Avatar
Thanks Rick I got a volt meter to night you've been a big help
Old 08-23-2003, 07:50 PM
Let me know if you get it fixed. Otherwise we will keep trying.
Old 08-23-2003, 07:52 PM
Bulld0g's Avatar
I'll keep you posted do you want me to post on the form or email you
Kevin
Email
Old 08-23-2003, 07:53 PM
Bulld0g's Avatar
Cool you got it
Old 08-23-2003, 07:59 PM
Bulld0g's Avatar
oh buy the way I've got duel fan so I don't think its the motor it would be strange that both of then would go at the same time
