Old 08-25-2003, 06:10 AM
R U YELLA's Avatar
Ed Digges
Cobra Make, Engine: Kirkham #328 w/ 390FE
Default Remote or Non-remote Oil Filter?
What are the pros & cons of each? Also what about a Sump? What are the AVG. costs?
Catch ya later
Ed
Old 08-25-2003, 06:50 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Off angle to allow the filter to be removed, but attached to the engine.
You are going to have to see what you end up with. The filter may interfer with the frame like it did on mine.
Just a thought.
Old 08-25-2003, 06:52 AM
hcollado's Avatar
Cobra Make, Engine: Everett/Morrison- Boss 302 Stroked W/351W heads and a whole bunch of ponies
Default Remote Filter
I would have to say that you should definiyely have a remote.
1) Easiness of changing the filter.
2) If you are running an oil cooler, you would want to filter the oil before it gets there.
3) You could use two filters, if you like over-kill like I do.
4) You could use a larger than normal oil filter.
A Sump?? If you have the room, go for it but they take up a lot of room.
Hector Collado
Everyday is a Holiday ... every meal is a banquet.
Old 08-25-2003, 08:06 AM
Back in Black's Avatar
Default I had the same problem with long filters
My babe and I were getting ready to take off to the Pacific International Raceway in Kent, WA for the Historics not long ago.. and I noticed a small drip of oil under the motor.. the long filter was riding on my spaceframe and had cracked. Could have ruined our day if I had not been aware..
I quickly jacked it up, changed to a short filter, checked the oil level and we were off... be careful where you mount it...
Old 08-25-2003, 10:03 AM
Rick Parker's Avatar
BIB:
What short filter are you using.
