09-11-2003, 07:23 AM
Cal
Finally, a really BIG big block
Ok, it won't quite fit into a cobra, but this is the largest engine I have ever seen. And it's Japanese, makes 5.6 million lb/ft of torque
http://www.bath.ac.uk/~ccsshb/12cyl/
09-11-2003, 07:36 AM
Big blocks
Is it real or a replica?
09-11-2003, 07:42 AM
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
replica
It's a Replica of the one they built before this one!
grumpy
09-11-2003, 07:48 AM
Cobra Make, Engine: era#671 Keith Craft Motor
Its the next Generation Cammer !
09-11-2003, 07:55 AM
Cool!
I'll take 2!
Will they fit in my garage?
09-11-2003, 07:57 AM
MA
Cobra Make, Engine: Butler with home-rebuilt 393 Cleveland stroker(Ya---ikes!)
Mr. Fixit
....I figured if anyone can do it YOU can! Therefore, I've just sent you a deposit---the plan is---we forego the "significant engine setback" built into the Butler---and then...........  ..well you take it from there---maybe with an assist from Ed Combs......
Chow,
Freddie
09-11-2003, 07:58 AM
TN
How many QTS of oil will it take, and were is the dip stick??
09-11-2003, 08:29 AM
Big block
I thought these were built in South Africa!
09-11-2003, 08:38 AM
Ed Digges
VA
Cobra Make, Engine: Kirkham #328 w/ 390FE
It's more like a great big block!
Catch ya later
Ed
09-11-2003, 08:55 AM
VA
Cobra Make, Engine: Former Owner of both Superformance #2666 Roush 427IR and Superformance #1601 Ford Crate 460CI - 486 HP 510 ft\lbs TQ
Nah!
Its really a Stroker Small block!
Seems like the Stroke to Bore ratio is a bit excessive. I don't want to be anywhere near it when it throws a rod. Although at 102 RPM that's probably not a problem.
JB
GUMBALL!
09-11-2003, 11:35 AM
WI
At 102rpm on a scale that size I bet the moving parts are still moving fast enough to soil anyones pants standing near it during a catastrophic failure.
Brent Dolphin
09-11-2003, 02:42 PM
Il.
Yeah sure....
But can we hotrod it and put a supercharger on it?
Who said...."You can never have too much horse power" ?
That is one big Mutha.
09-11-2003, 02:57 PM
can I keep my TKO or do I need to upgrade to TKO 2 when I order this engine?
Roger
09-11-2003, 03:08 PM
Cal
Re: Yeah sure....
It's allready turbocharged and a two-stroke. It is blown, and it fires each cylinder every crank rotation. If I could convert my BB chevy to be a two stroke, it would essentially DOUBLE the engine displacement. That would be cool, an "SS 792" instead of just a 396.
I wonder how much torque it's starter motor has to make, to turn that monster over?
09-11-2003, 06:57 PM
I work on these. While they may be jap owned, Sulzer is obviosly a German engine, and German design. They don't use starter motors, it injects "start air" into the cylinders in the proper sequence, then you open the fuel rack and bang.....Bang...BangbangbangBabababbaba.....! If you want to go in reverse, you stop the engine, slide the cam for the fuel pumps and fire her off backwards!!!!!! And yes, you stay in line with the crank if you suspect trouble brewing! We could idle ours at 19 rpm.
2000 Ford Lightning
12.71 @ 107.79
Cobra Dreams...
Can I now say "Build in progress" since I have a garage full of donor parts???????????
09-11-2003, 07:11 PM
Wow
I wonder if they'll be able to get it smogged?
Duane
09-11-2003, 07:18 PM
Cool motor! What gear head couldn't appreciate an engine THAT BIG!!
19 rpm idle speed. I tell you the "numbers" on this thing are just amazing! Yeah, if it "feels" like trouble, get in-line with the crank, even at 19 rpm, LOL.
Ernie
09-11-2003, 07:31 PM
MO
Cobra Make, Engine: SPO 2715
Nope
You guys missed it.
Oldest trick in the book!
Everyone knows Japanese are small people, the motor isn't "THAT" big!
Eric
09-11-2003, 07:50 PM
DOH!!! .....and I fell for it hook line and sinker! ha ha
Ernie
09-11-2003, 08:02 PM
WA
Will I have to go to a C6 to run that in my Mobra?
