Old 09-28-2003, 08:34 PM
ENTDOC's Avatar
Default turn signal problem
The latest electrical problem is the turn signals,flasher ect. I have a flamming river column with GM wiring harness in column,ignition switch is on dash in usual cobra fashion.My EZ wiring harness has terminated ends for the turn signals,flasher,brake switch ect..that plug in to the column wiring.It is an easy plug up ,but no juice to the signals.How do I get a hot wire to the column to operate the signals? thanks;chuck
Old 09-28-2003, 10:01 PM
Bill E's Avatar
Did you check the fuze?
Bill Emerson
Old 09-30-2003, 10:23 AM
TonyMadrid's Avatar
Cobra Make, Engine: A&C 351W, C4
Default power to column
Two items: First, there should be some power wires from the column harness that would run to the fuse panel. Such as horn, turn signals, hazard lights. Has it already been wired or are you still in the process?
Second thing, if it is already wired in place and you still have no power, make sure that the column harness is grounded and you may even have to be sure that the column itself is grounded.
Good Luck,
Tony
