Old 10-14-2003, 06:14 PM
Send a message via AIM to ravedemon
Default undercoat or "better sound"
i'm writing this b/c i was thinkin of installing a material under and on the inside of my car called http://www.quietcoat.com/ i believe that if i install this the overall sound of the motor will sound "beefier" other than rattly from the fiberglass...... also to keep the loud exhaust noise outside the car and to quiet it up a lil on the inside.....also to possibly keep the motor heat out of the cockpit (for summer time), and to help keep the heat in (in the winter) if any one used this or thought of useing it please contact me and steer me in the right direction, so it wouldn't be $500 down the drain...
thanks
Jason
Old 10-16-2003, 12:44 AM
Cobra Make, Engine: Unique Motorcoach, carburated,2.5L Turbo,German redblock 5-spd. w/air condition, Radio, CD, Power antena
Here is another Idea, Go to the hardware store and buy two gallons of Fibered Asphault Emulson and coat the underside of the body using both gallons. You will end up with about one eight inch coating of rubberized insulation costing about $40 dollars.
Bill Markley
william.markley2@tusd1.org
Tucson Az.
Old 10-16-2003, 02:09 AM
REDSC400's Avatar
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Hi Jason:
If you were to prioritize your desires regarding the noise, exhaust note and heat, which is most important to least important?
1) Beefier Exhaust Note
2) Keep Exhaust Note Outside of Car vs Inside
3) Provide Barrier for Thermal Heat from Motor
4) Provide Heat in Winter
I am not sure there is one good solution (manifested as a single product) for all four of these. And #2 is probably impossible to attain (have you tried ear plugs?) while 3 and 4 seem contradictory. 4 can be achieved with the installation of a heater.
As for 1... add one Big Block.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
Display Modes
