Old 10-28-2003, 02:44 PM
Angry TR-3550 TKOII (help with installation plz!)
Hi !
I just bought a Tremec TR-3550 TKOII and I got some problems to install it.
The "yoak" (sry 'bout my english!) on the driving shaft are too small but...it s ok, I already resolve this litle prob.
The other real problem are the cross-member who support my transmission. He touch the tail of my Tremec and I cant install it. If I, the transmission goes up and I dont think that s a big idea...
What did u do with ure cross-member ? Can I buy another one or the only solution that I have are to weld the brackets backward...?
THX a lot
I know that I m not the only one to have a TR-3550, so I m pretty sure that I will get some help here !!!
THX Again !
Hugo
Yeah! Made out 682 out of tha flywheel on a dyno with my original 302HO small block. 4 seasons and my baby still alive without opening the block 1 ****ing time dudes. VIVA LA COBRA !!!
Old 10-28-2003, 02:51 PM
Mr.Fixit's Avatar
Not sure I understand your problem completely, but:
A lot of cobra builders end up trimming part of the tailshaft off the tremec, the torque arm mount that is behind the tranny mount, below the outut shaft. It's a rib of aluminum shaped liek a triangle.
Custom crossmember may be necessary.
What kind of cobra is this?
Old 10-28-2003, 02:57 PM
It s a 90. A new one, not the legendary ones :~(
My crossmember, with the support of transmission, touch the tail of the tramsmission and if I cut the crossmember, he will loose all his strenght...
Old 10-28-2003, 04:06 PM
surfer44's Avatar
Cobra Make, Engine: Hi-Tech Serial 0122 66 428, Tremec 3550. AMP 9" Ford IRS
Send a message via AIM to surfer44
I just put in a Tremec 3550 behind my 428. I had to notch the crossmember and weld on a plate to hold the rear transmission mount. _______ ________
\______/
I'll try to get a picture to you tonight.
Neil Brady
"Life is not a journey to the grave with the intention of arriving safely
in a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out and loudly proclaiming:
"WOW, what a ride!!!"
Old 10-28-2003, 04:24 PM
Mr.Fixit's Avatar
oh, it's one of THOSE cobras. I don't know squat about late model mustang cobras, disreguard my previous post.
Old 10-28-2003, 05:06 PM
surfer44's Avatar
Unhappy
Me, neither also I must not know how to read. Thought I had a chance to help someone finally! Oh Well !!!
Neil Brady
Old 10-29-2003, 04:10 AM
Surfer44
I think that can help me a bit. It look like the same problem.
If u can get this famous picture, it will give a good idea on "how to work it" !
Thx a lot to you guys !
PS: Surfer...The problem are not that u dont know read...it s that I cant write correctly ! loll
Old 10-29-2003, 06:01 PM
surfer44's Avatar
Hope this helps . Welds need to be cleaned up and redone.
Neil Brady
Old 10-29-2003, 10:02 PM
I see ! I cant get a better picture
Thx a lot for ure help and the rapidity of ure reply.
Until 30 minutes ago, I was going to break the tack weld on the brackets and pull it 1 inch and half bacward.
Bruce Hyland from Tremec reply to my e-mail that I send to him, and gave me a part# for another crossmember.
I ll go check it right tomorrow and if it s the good one, pretty sure of it, I ll will get my yoke friday and can run my Cobra a last time b4 the winter ! heeehaaa !
THX again for the precious help !
Old 10-29-2003, 10:13 PM
oh ! If someone are interest by the part#, it s a Ford part,
#E6ZZ-6A023-a
