Old 11-03-2003, 09:23 AM
Cobra Make, Engine: 65 la exotics 351W supercharged
Default help 351W desktop dyno
Can some one run these desktop dyno #'s for me.
351W
8.7 to 1 compression
stock ported heads with 194/160 valves
edelbrock performer intake
crane cam adv. duration 286/296, lob sep. 112, lift .502/520
roller rockers
windage tray
holley 650 carb
supercharger @ 8lbs of boost
Thanks for you help. Jay
Old 11-03-2003, 03:21 PM
Default Desktop Dyno Results
Jayem,
If you can get me your email address I can email you the file for you motor. Here are the peak numbers:
491HP at 7000rpm (485 @ 6500)
450FT#s at 5000rpm (346 @ 2000)
I think that I have the right cam. I have the supercharger as a regular Paxton.
If you have a fax I can even send it that way. You can call me at (808) 479-8508 if you like.
Ciao,
Shawn C.
Old 11-03-2003, 04:07 PM
Default Dyno numbers.
You have mail. Let me know if it didn't go through.
Ciao,
Shawn C
Old 11-03-2003, 07:36 PM
HighPlainsDrifter's Avatar
Cobra Make, Engine: F5 Roadster
Thumbs up Specs
Hey Jay,
I ran your #'s, they look good.
390 hp/ 455 ft/lbs @ 4,500 rpm
456 hp/ 435 ft/lbs @ 5,500 rpm
484 hp/ 391 ftlbs @ 6,500 rpm
Looks like it makes good power through 6,000 rpm;
torque starts falling off after that so without an intercooler,Id shift at 6K ,you'll just heat the air charge after that and actually slow down holding it in gear even though the dyno # says it keeps climbing, in reality my paxton mustang went 2 tenths faster short shifting at 5,500 rpm rather than 6,000. Maximum torque in the midrange will move you quicker than maximum HP on top.Oh yeh, 1st and 2nd gears will probably just light up anyway, so you'll probably have to short shift 1st at 3K and 2nd at 5K and be pointed straight in 3rd gear ,I spun it twice going into the passing lane,managed to keep it on the road.Keep the shiny side up!
Perry.
Old 11-04-2003, 06:41 AM
Thanks for your help. Jay
