Old 11-29-2003, 09:52 AM
ENTDOC's Avatar
Default clutch advice needed
I did a search and it was helpful but would be intertested in newer responses.I am considering a centerforce dual friction clutch for the 427so.I am open to comments or suggestions on this choice however as well as flywheel choices.Thanks as always. chuck
Old 11-30-2003, 03:55 PM
ENTDOC's Avatar
ttt
Old 11-30-2003, 05:12 PM
David Kirkham's Avatar
Original Shelby Owner
Smile
Chuck,
Give me a ring tomorrow and I will give you all of the part numbers we use. We don't use the double disk, but I don't think you need it.
We can give you all the part numbers you could ever need.
David
Old 11-30-2003, 05:30 PM
CC Member / Sponsor
The dual friction clutch on the 427 works very well. Give us a call.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
Old 11-30-2003, 06:21 PM
Cobra Make, Engine: Arntz/Butler 3 engines(mild to Wild)
Chuck,
I f you are making over 500 H.P. you might consider an aluminum flywheel since you will want to transfer H.P. and less torque to the gears. Hayes makes a nice competition clutch for road race(talk to dave at ext.312) if you don't mind a hefty peddle push. Steve
Old 11-30-2003, 10:24 PM
Cobra Make, Engine: Levy Racing built FFR w/351W
I was worried about what clutch to use with a lot of HP. I am using a Quartermaster setup. Flywheel, clutch, pressureplate is 18 lbs. Good to 800 HP. Distributor is Levy Racing
Old 12-01-2003, 08:10 AM
Chuck, I have the quartermaster setup that Bart just referred to. It is more of a race set up. The clutch will slip just a bit and then bites. Also, because the clutch is smaller, 8 inches, the clutch pedal is stiffer than you might like. But it is awesome on the track. Scott.
