Old 12-16-2003, 03:58 PM
Cobra Make, Engine: Unique 289 FIA,302 Crate,Holley 600cfm
Then there is always vinegar.
Best
Scott
HANDLE WITH EXTREME CARE: This product contains minute electrically charged particles moving at velocities in excess of five hundred million miles per hour
Old 12-16-2003, 04:35 PM
The Coke works because it has a very high phosphate content. Remember when we had to stop using phosphate based soaps and detergents? They worked well, but had to be removed from the environment. Never mind that 2/3 of Florida and 1/2 of western Canada is phosphate rock. Anyway, always be careful using soaps, (simple green, joy, tide, etc.) early in the cleaning cycle. The soaps will lift the oils and then cause them to seep deeper into the concrete. This only compounds the staining. Absorb as much as possible with oil dry, cat litter, dirt, portland cement, etc. Then start the soap application. But put more absorbant on very soon after. This will wick the oil to the top rather than gravity pulling the stain deeper. Some soaps emulsify (make water soluble) the oil. But ALL soaps break the surface tension of the water droplet and allow it to pass thru smaller pore spaces. This is why it will go deeper into the concrete.
RP
Old 12-16-2003, 05:08 PM
G.R.'s Avatar
Send a message via Yahoo to G.R.
Whatever method used using an acid/or Bleach solution make sure you are venting everything--and if you value your ability to continue breathing do your lungs a big favor and wear a proper mask for filtering out the resulting fumes--DO NOT EVER use bleach if you have previously cleaned with any product that has ammonia in it--you'll produce a great chemical weapon called Chloramine gas or straight bleach mixed with water creates Chlorine gas and these gases only rise about 6/7 ft off the ground
Old 12-16-2003, 05:16 PM
REDSC400's Avatar
Send a message via AIM to REDSC400
the Zen way of dealing with a grease stain is to ignore the stain and consider it a natural progression to an inevitable one-ness... One larger... more meaningful stain... spreading.... growing... to eventually consume the entire garage floor.... one large stain... undifferrentiated.... uniform.... thus... no stain.
Solution.... spew about 14 quarts of 20-50 Redline all over your floor and squeegee it in, everyehere, evenly....
Voila.... what stain?
That's whats gonna happen anyway, over time.
Or... Hot oil, babes in bikinis.... hot oil wrestling on the garage floor.... call me when this happens... I'll bring the beers...
Who's in?
Art in CT
Old 12-16-2003, 05:20 PM
G.R.'s Avatar
Me
Old 12-16-2003, 05:41 PM
BT SNAKE's Avatar
Cobra Make, Engine: Midstates Cobra, RFGT40
Thumbs up
Go to Costco or Home Depot and get some of this stuff. It's the best I have found that's sold commercially...Sheese, all this for a grease spot, I'm starting to sound like Martha Stuart.
Hersh
Old 12-17-2003, 07:20 PM
BMK's Avatar
BMK BMK is offline
Hi Hersh
We will be even more worried when you start wearing her dresses and make up.
Oh nooooo - someone said you already are
Not a good look.
Catch up with us on 'Australian Club' -site when you have a moment.
Will head over to see Rob at Roarin' soon. Have been busy with my car here. Goes in to be painted in April if I don't wear it out in the meantime. Done about 3500 miles in two months now.
I will ring you soon In the interim have a great Christmas.
Bernie
Bernie Knight
Mt. Gambier South Australia
Home of "Weekend at Bernie's #2" - March 13th and 14th 2004
Bernie Knight
Old 12-17-2003, 07:49 PM
BT SNAKE's Avatar
Thumbs up
Thanks Bernie, I'll do that. But don't listen to those other guys. I haven't worn a skirt...Huh.. I mean Kilt for at least two days..
MERRY CHRISTMAS TO ALL OF YOU CAR CRAZY OZZIES.
Hersh
Old 12-18-2003, 04:20 AM
BMK's Avatar
BMK BMK is offline
Hersh,
Got your Post on Australian Club Cobra.
Will ring for sure in the next few days.
Bernie
Bernie Knight
Bernie Knight
Old 12-18-2003, 04:53 AM
Cobra Make, Engine: None Yet
Be careful using Muriatic (sp) acid. The fumes will cause bad rust and corrosion. And residual acid will give off fumes that can cause lasting damage.
auto10x
Bill
Old 12-18-2003, 06:29 AM
CC Member / Sponsor
Try WD-40. It also works well to remove crayon marks off the wall.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
Old 12-18-2003, 06:38 AM
Double Venom's Avatar
Ohhh, now Tom has hit it on the head!
WD-40: Takes grease, I mean real grease, oil, butyl window seal, (don't ask!) upholster spray glue, and dozens of other no-no's right out of carpet, upholstery, off your fingers etc.!
DV...Water Displacement-test 40
  #33 (permalink)
Old 12-18-2003, 07:19 PM
Alex Donghi's Avatar
Cobra Make, Engine: SPF #821,Southern Automotive 427 Side Oiler w/2x4
Tom really hit on something... you ever bought something with one of those price stickers on it that the *@!*&^ glue just wont come off Like the bottom of a new pan or something Yup WD40 melts it off
Alex
  #34 (permalink)
Old 12-18-2003, 09:38 PM
Cobra Make, Engine: Nothing yet- spending money for Cobra on daughter and son's college educations!
Avoid using Muriatic Acid, unless it's diluted 50/50 or more.
If you use it in too concentrated a solution, it will etch your nicely finished concrete, making it look like 60 grit sandpaper, or worse yet, may take chunks of concrete off, making it look like your sidewalk did after mistakenly using Road Salt to de-ice it in the winter.
After using your solution, scrubbing LIGHTLY, immediately wet-vac
it, rinse w/ cold water, and wet vac that. Chances are, That will be the cleanest spot in the entire garage. Also, use powered ventilation, such as one or more Box fans, one to force fresh air into the garage, and another to help draw the fumes out.
Speaking from experience (cleaning the deep end of an outdoor pool where I thought I had adequate ventilation(total dead air space), you can't believe how much those fumes can burn your nose, throat, lungs, and sting where you have a cut )
Be Careful!!!
-Bob
