Old 01-25-2004, 08:14 AM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
Default Trunk latch
I have a question for all of you Classic Cobra owners out there. Does anyone know what the trunk latch they sell as part of the kit is from? I am finishing up a car and can not get them to send me the latch. I have been waiting for months and at one time they said it was on the way but it never showed.
If anyone can tell me were to find one I would be most grateful.
Old 01-25-2004, 08:18 AM
Dan Semko's Avatar
Hoosier Gashole Emeritus
Check with Paula or Enzo at the Finish Line.
DDS/The First Edition
"In debates on ethically contentious issues, it is never wise nor polite to deride or belittle another person's delusion."
Old 01-25-2004, 08:32 AM
Dan,
Did that they did not have anything we could use.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 01-25-2004, 08:35 AM
Bud Man's Avatar
Cobra Make, Engine: Former Owner/Builder of KMP142 427 Sideoiler, Tunnel Wedge, Aluminum heads, etc.
Bruce:
There are two trunk latches that are commonly used. The difference is the width between the mounting holes. One is 36mm from mounting hole centerpoint to centerpoint, and the other is 44mm. Your car may accommodate either. Correct for original cars is 36mm.
A great source for original Cobra parts is Holden Spares. Their website is www.holden.co.uk. I bought the majority of my body hardware (it is OEM) from them. Their prices are fair, and they ship promptly. Surprisingly, although they ship from "across the pond" the shipping costs are comparable with domestic companies.
Bud
Old 01-25-2004, 09:00 AM
Bud,
Thanks for the hint but the OEM style will not work on this car due to license plate placement. The Classic uses a spring loaded latch and pin set up no the OEM turn hook type. The outside handle on this car will be a fake and the trunk will be opened by an electric solenoid with a hidden switch.
Bruce
Bruce Edwards
Old 01-25-2004, 11:12 AM
Cobra Make, Engine: West Coast Cobra weber fuel injected 557 C.I.. 800H.P 760LBS. TQ. Magnum T56
Send a message via AIM to MAXVELO
Default trunk latch
Beleive it or not but most of the trunk latches that are used are the same as those used on most truck camper shells.....FYI
WHEN YOU HAVE MORE HORSEPOWER THAN YOU NEED ITS STILL NOT ENOUGH!!!!!!!
Old 01-25-2004, 11:28 AM
I can not use the turn style latch like on a camper.
It must be a pin and spring loaded latch like on your car trunk. This style lends it self well to cable operation. When the trunk lid is closed the pin aligns with the latch bolted to the floor. As the pin is pressed into the latch a spring loaded hook moves around the pin to hold the trunk down. No outside handle is needed. To release the lid a cable can be pulled to release the spring loaded hook thus releasing the pin and allowing the gas charged struts to lift the hood hands free.
Bruce Edwards
Gemini Motorcars
Bruce Edwards
Old 01-26-2004, 05:48 PM
How about it all of you Classic kit car owners any know who makes the trunk latch???
Bruce Edwards
