November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-18-2004, 08:06 AM
Default side pipe delimma
Hi, I am new to this site and I'm hoping that someone could give me some information about a header side pipe configuration. I work at Coventry Restorations (PA) and we are currently working on a cobra kit car that incurred damage to the drivers side. In the accident both the side pipe and the header were destroyed. The only relevant information I have on the configuration is; the pipes were made by SMC Co (which I understand is out of business), the engine is a 289, the header-to-head flange has ports with the dimensions 1in x 1 5/16, the header does a hard 90 down and shortly there after makes a 45 or so out to the side pipe cutout, the side pipe and header are connected with a square flange in which all of the pipes have a diameter of 1 1/2 inches. We have looked in numerous catalogues and cannot locate an exact match (biggest problem being the square flange). We are looking to purchase both driver side and passenger side configurations. Any enlightenment that you can provide would be greatly appreciated. Thanks, Adam
Old 02-18-2004, 08:18 AM
Adam, do you know what brand Cobra it is? If you could find out, you could just call the manufacturer and get a set.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 02-18-2004, 08:22 AM
clayfoushee's Avatar
Cobra Make, Engine: Unique, 427SO, it runs
Blykins is correct. Since the bodies and frames of various replicas are different, one needs to know who manufactured them. Many manufacturers fabricate their own headers, so they are usually the best source.
Clay
Old 02-18-2004, 08:25 AM
Cobra Make, Engine: Everett-Morrison, 347 Tri-power Stroker
My Everett-Morrison has the square flange which is connected with 8 bolts (guessing they are 3/8 or 7/16").
You can contact them at http://www.everett-morrison.com/
EM is currently producing a new version of their car, so I can't qualify whether they have headers/sidepipes in stock for the old version, (assuming that it meets your needs), but they can probably supply you with blueprints or dimensions.
- Dan
Old 02-18-2004, 10:19 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Best bet is to just have a fabricator make up a set...
Dan, even EM has different sets depending on the serial number. I ordered a set from them after giving them my number and they were about 4 inches from hitting the hole on one side and about 3 on the other. After calling them they said from my serial number that was when they were playing with set back distance and without the pipes they didn't really know where the engine was sitting in the frame...
Jack
XSSIVE .....
Old 02-18-2004, 10:22 AM
Jack,
Good to hear from you... as always, feel free to correct me. Of course, you might have had some difficulty with the side pipes because of that chevy-stuff you have under the hood
Hope all is well with you and yours!
- Dan
Old 02-18-2004, 10:46 AM
rdorman's Avatar
Renegade Nuns on Wheels
If you know who the car was made by, call them. Otherwise have a set made up.
Rick
OhioCobraClub.com
LondonCobraShow.com
Old 02-18-2004, 11:31 AM
Hotfingrs's Avatar
What chevy stuff? Valve covers say powered by Ford
Jack
XSSIVE .....
Old 02-18-2004, 11:34 AM
Hotfingrs's Avatar
Dan, just waiting for Crower to make my lifters, then I can concentrate on putting the engine back in the car. Was told 6 weeks for them about the middle of January...so hopefully sometime before the end of the month...or early March will do.
Jack
XSSIVE .....
