Old 02-26-2004, 06:50 PM
mgilbert's Avatar
Cobra Make, Engine: la exotics 289 5speed 9in. 270hp 295tq w/ g-tech
bruce, no i do not want to pull manifold it's not broke HA HA . could the motor mounts be hiding them slightly? any idea about threaded holes in block. i wish i work in an auto shop & not a print shop
Old 02-26-2004, 06:56 PM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
The threaded hole on the left side is for the factory clutch Z-bar pivot.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 02-26-2004, 07:09 PM
mgilbert's Avatar
bruce, i'm going to find these sob-ing #'s. those #'s have me P.O.ed. their i feel better now. Thanks again
Old 02-26-2004, 07:36 PM
I have a 289 and a 302 block at the shop and I will check for the location in the morning. Sorry my memory is not working.
Bruce Edwards
Old 02-26-2004, 09:13 PM
G.R.'s Avatar
Send a message via Yahoo to G.R.
I have a 289 hi-po in my car, the casting numbers on the block are just above the starter ---very hard to see---took me awhile to finally locate them---in frustration I finally rubbed a piece of chalk in the area and lo and behold there were the the numbers.
FWIW hope it helps.
Old 02-26-2004, 10:28 PM
mgilbert's Avatar
hello G.R. are the numbers on a little ear or pad that protudes off the block or on the block directly. thanx for your reply mark gilbert
Old 02-26-2004, 10:34 PM
G.R.'s Avatar
Post
Mark they were just below the protrusion above the starter, rather small and hard to see
Old 02-26-2004, 10:41 PM
mgilbert's Avatar
G.R. later i'll give it another try. thank you, thank all of you catch you all later
Old 02-27-2004, 07:42 AM
Mark,
Right rear side. You may have to remove the starter to see it.
Bruce Edwards
