December 2025
Old 03-23-2004, 06:21 PM
Cobra Make, Engine: ERA 2092
Default Fuel pump/weber carbs SBF
What kind of fuel pump is needed for the weber carb setup thanks Bob
Old 03-23-2004, 06:28 PM
Can a stock EFI fuel pump (mounted inside the stock fuel tank) create TO MUCH pressure and damage the needle/seat on the floats in the carb?
Ernie
Old 03-23-2004, 06:32 PM
Banned
the weber carbs require a very low fuel presure, not more than 3 1/2 lbs. do not use a efi pump!
Old 03-23-2004, 06:56 PM
Cobra Make, Engine: ERA #122 (Sold) : Ford GT #484 Heritage Edition; 2008 GT500 Red/Black
Per Cal and Enzo you don't want to run more than 3 lbs..I am running a carter mechanical pump at have a regulator set at 2 lbs.
Matt
2006 Ford GT #484 Heritage Edition
2003 Hummer H1 OpenTop
2003 Hummer H1 Wagon
Old 03-23-2004, 07:50 PM
How does the pressure regulator work on an electic pump?
With EFI there is a return line so excess fuel (in this case pressure) is returned to the tank.
Ernie
Old 03-23-2004, 09:22 PM
Cobra Make, Engine: 427SC Unique
A Carter 4070 pump is a great pump for Webers. Regulate it at 3 to 3 1/2 lbs.
Avail through Jegs or Summit for about 60.00
Brent
Old 03-24-2004, 06:23 PM
I RUN 2.5 LBS WITH A REGULATOR, AND FUEL PRESSURE GAUGE IN THE DASH FOR EXTRA MEASURE. RUN THE CARTER ELECTRIC FUEL PUMP, WIRED TO AN ON /OFF SWITCH NEXT TO THE DRIVERS SEAT, NOT, REPEAT, NOT WIRED TO THE IGNATION SWITCH.
Old 03-25-2004, 04:23 AM
Original Shelby Owner
The floats only weigh 25.5 grams so it doesn't take much pressure to overcome their ability to close the needle and shut down the fuel stream. EFI pumps run a minimum of 35 psi, and some up to as much as 100 psi (Mercedes). A fuel return line, however, is always a good idea, even with a standard electric or mechanical pump.
I especially like Terry K's idea of the on/off switch that is independent of the ignition. I had that set up in an old Corvette years ago. Makes for a nice security device, as well.
