Old 05-06-2004, 01:35 PM
Cobra Make, Engine: sold BDR #123 351w, Tko 17" full polished wheels
Smile Polishing a stainless steel fuel tank
I have a stainless steel fuel tank in my BDR. I wanted to shine it up a bit using a random buffer and some rubbing compound or polishing compound but I am concerned about static electricity giving me a big bang. Any thoughts on this??? I am not planing to take it out of the car just buffing the bottom. Oh yes it does have fuel in it. Thanks
Old 05-06-2004, 02:35 PM
flipper35's Avatar
I polished my aluminum tank while it was on the car with no static build up. If you are concerned you can always get an ankle strap with the cable that snaps on the ankle strap and has a clip on the other end. Clip it to a ground and to static build up. Computer shops usually have them.
Brent Dolphin
Old 05-06-2004, 05:12 PM
I use MetalWax. It is a two-stage process; first stage is a gentle acid that goes on with a watery rag to clean the surface. Wipe dry with a separate cloth. Then use the Wax. This company says that the compounds leave a lit of microscopic grit, which attracts dust and dirt, thus clouding up the surface, thus requiring MORE compounding, which leaves the girt, etc etc etc.
Go to a Harley motorcycle show, the ones with all sorts of vendors. There is usually some guy with a metal polishing system that polishes the bottoms of aluminium cans, as samples.
Edley, The Cobra Rogue!
Old 05-06-2004, 05:14 PM
flipper35's Avatar
Hey, I use the metal wax too. I did have to polish the aluminum to get it shiney first. Stays shiney a long time now.
Brent Dolphin
Old 05-06-2004, 05:16 PM
What did you polish it with? Compounds?
Old 05-06-2004, 06:10 PM
flipper35's Avatar
I used a 6" spiral wound cotton wheel on a drill with emery compound, then a regular 6" wheel with tripoli compound. I will see if I can get a grab from the video or just post a short section of the video that shows before and after. It made a big difference.
Brent Dolphin
Old 05-06-2004, 08:24 PM
Cobra Make, Engine: Shell Valley- smallblock grenade w/ the pin pulled
Default yeah, I polish...
If you want some serious industrial strength metal cleaner/polish try hitting a truck shop or dealership. The same stuff I use on my heavy equipt makes small work of anything on my Cobra. Yeah, I polish a thing or two...
"If you're not racin' it, you're wastin' it!"-Me
