Old 04-19-2007, 06:39 AM
Lawler's Avatar
Cobra Make, Engine: Lone Star Classics (LS427)
Default Soft Top Question
What brand of soft top did you install on your cobra? Do you like it and what problems if any have you had with it? I will be installing one on my Lonestar.
Lawler
Old 04-19-2007, 07:47 PM
Cobra Make, Engine: ERA 742 / 428 FE
Need to contact the manufacturer on this one. Robbins makes original Cobra tops but they will fit very few replicas (Kirkham, ERA). Not familiar with Lonestar but tops and side curtains are tricky. Luck to ya.
Old 04-19-2007, 07:58 PM
Cobra Make, Engine: StreetBeast 66 replica 302 350HP
I have a soft top and side windows, also A/C and heat, makes the car more comfortable, however, I run with the top off, more than I do with it on, I mostly use the top in the winter, it cost over a thousand dollars, so you need to consider that also, mine came from the manufacturer, however most large cities have a company or two that will make one for you, call your local trim shops, also you can search the various Cobra manufacturers web sites
PapaJohn
Old 04-19-2007, 09:15 PM
Banned
Won't fit the Kirkham without major modifications, due to higher roll bar, I gave up on the top and got s tonnel cover instead. . .
Old 04-20-2007, 04:12 AM
Dwight's Avatar
Default Tops
Lone Star has a 94" wheel base and most of the other Cobras have 90". The Lone Star doors are 4" longer, therefore most other tops will not fit. You can buy the frame and have a local shop make the top. We have a couple of guy here who have made their soft tops.
Dwight
Old 04-20-2007, 07:01 AM
Lawler's Avatar
Thanks RedEspirit
Old 08-15-2007, 09:13 AM
Registered User
Default Lone Star Soft Top
Hi Lawler,
I know this thread is over 4 months old. I was wondering if you ever found a solution for the soft top. I'm in Houston, so I'm not too far away from you. did you find a local shop or did you have to fabricate one yourself?
Eric
