Old 05-24-2007, 12:30 PM
priobe's Avatar
Default E-Brake pictures please
Hello all,
I am currently using the Wilwood E- brake caliper that is separate from the rear caliper. I am hoping that someone is using a simular setup for their E-Brake.
If not please if you have post some pictures of your e brake setup.
Or did you guys just say the hell with the ebrake?
Old 05-24-2007, 12:36 PM
priobe
I have the same setup on my Cobra. I'll take some pictures when I get home tonight. I will post them on my gallery and let you know when they are there. I do not have the cables hooked up to them yet but you will get an idea on how they bolt up.
Terry
Old 05-24-2007, 01:22 PM
priobe's Avatar
Hey Terry,
I have them bolted up but I dont like the way they work.
I have the Lokar handle mounted on the side of the tunnel and the cable that came from Everett Morrison. I am trying to figure out if it is the leverage from the handle on the side or the cable supplied by EM.
Is your handle mounted on the side?
If so can you provide some pics of that also.
Old 05-24-2007, 02:10 PM
KarlCSX2498's Avatar
Cobra Make, Engine: CSX2498 has been in our family garage since '68....Scratch built aluminum bodied 427SC Cobra, 427FE, CSX3000 chassis specs, 95% finished, only needs paint.
Default E brake photo
Hello, Here is a photo of the wilwood ebrake on my CSX4000 suspension. The caliper is on the front of the upright and the ebrake on the rear. I fabricated the bracket out of 1/4" mild steel and I will have it CNC machined out of 6061 aluminum for the final product. regards, karl
...fixed the pic link..ron
Old 05-24-2007, 02:47 PM
priobe's Avatar
Karl,
Are you using the Lokar small handle mounted on the side or the longer Lokar handle mounted to the floor?
Old 05-24-2007, 03:19 PM
Default ebrake handle
hello, yes, small handle and it is the original style side mount that bolts to the bracket that is welded to the chassis. i hope this helps. regards, karl
http://www.robsdrive.com/cobra/karls-cobra/slides/Karl's%20Cobra%20(81).html
Old 05-24-2007, 03:36 PM
Rick Parker's Avatar
88 T Bird Turbo Coupe with the E-Brake pivot on the caliper modified to allow activation from side pull (towards center of the car) insted of front or rear.
OEM CSX handle mounted on fabricated bracket.
[IMG][/IMG]
Old 05-24-2007, 09:49 PM
priobe,
My Cobra is a Classic Roadsters and my e-brake is between my seats on top of the tunnel. It is not installed yet. Look in my gallery and there is a picture of my Wilwood e-brake setup at the rotors.
Old 05-25-2007, 07:50 AM
priobe's Avatar
As far as cable for the Ebrake, is everyone using the Lokar cable?
Also my setup is a the 8.8 rear independent with the Lokar small handle.
I am thinking of changing the bracket.
Looking for some ideas.
Also, does anyone have this setup working and does it work well.
Old 05-25-2007, 08:27 AM
LMH's Avatar
LMH LMH is offline
Here's one I found on a Kirkham. I don't know anything about it but I sure would like to!
Old 05-25-2007, 08:33 AM
priobe's Avatar
Nice,
I am not sure if Kirkham will sell Ebrake parts if you did not buy their kit.
Hopefully more pics will start pouring in.
Old 05-25-2007, 10:09 AM
LMH's Avatar
LMH LMH is offline
Originally Posted by priobe
Nice,
I don't know either. It is the same caliper I use for the rear but I have never asked them if they would sell me a set of those. Too many other things to do first.
Old 05-25-2007, 11:38 AM
<<<As far as cable for the Ebrake, is everyone using the Lokar cable?>>>
I purchased a set of cables from a CClub member and they are excellent quality and perfect length. You can email or PM me and I will forward his contact info. I did have to alter the Lokar handle to make it pull from the bottom like the original handle. I will try to post a clear photo of that detail.
Later, karl
Old 05-25-2007, 12:14 PM
greg schroeder's Avatar
Here's the one that came on my Superformance. It's the deal to the right of the red fuel filter and gas line. There's a disk on the drive shaft for the pads to grip.
Old 06-16-2007, 07:04 PM
SF_SN888KE's Avatar
Cobra Make, Engine: Cutting Edge Replicas, 427 World block SBF, TWM Injection
great pics,
I'm also looking at e-brake ideas for my Cutting Edge Replica.
How does the cable mount to the Wilwood? angle and distance for the pull?
Also check out Pinion Mounted Parking Brakes and Line Locks.
http://www.tsmmfg.com/Pinion_Mounted_Parking_Brakes.htm
Ron; SF_SN888KE
Cutting Edge Replicas 427
Shell Valley Daytona #27
Old 06-16-2007, 07:14 PM
427sharpe's Avatar
A good hydraulic that I have used on my cars for years. I plumb into the front brakes for drag racing...
http://www.spidertrax.com/s.nl/it.A/...FQRngQodIDj6yw
Old 06-16-2007, 11:51 PM
Cobra Make, Engine: Cardiac, 428 FE
I had the TSM mfg pinion brake on my car and had to take it off. The disk isn't very tough and got out of alignment (probably due to tightening of the bolts). It made a lot of noise rattling against the caliper. I now have to find a better solution like the Wilwood unit but not sure I can get one to work with my full-floater rear-end.
Paul
