Old 05-30-2007, 06:36 PM
Cobra Make, Engine: FFR, 302/317rwhp Mass flo, AFR heads
Default Exhaust Experience
Hello all! I have discussed this matter on a different forum, but since i see that there is a lot of exhaust discussion here as well, i thought i would post my db and dyno results here also. I have a ffr, which comes iwth 2.5" ID diameter pipes, so my experience and results will vary from other kits that have more restrictive or different exhaust systems. However, my results should help some of you to chose what will sound best and create the most positive results according to your goals. I am running a 306 with a mass-flo fuel injection system from www.massfloefi.com with afr 165cc heads, and 9:1 compression.
4 into 4 header vs. shorty headers and J pipes
Only a small loss in hp over the 4 into 4s-j-pipes and shorties helped reduce noise.
cc inserts installed in j-pipes with packing(absolutely killed power) However, i never tested them without the packing material, but i could still feel a significant seat of the pants difference.
Classic Chambered cobrapacks vs. FFR pipes
DB comparison
FFR pipes with CC inserts in J-pipes
Results-while sitting in the car at idle 900rpm
Before-101db
After-98dbs
3 feet away from pipes
Before 102db
After 99db
While cruising at 2000rpm
Before 105db
After 102db
2200RPM
Before-107db
After 104db
Classic chambered Cobrapacks were the same as FFR pipes except were more mellow at idle by 2 dbs. However, at other tested rpms they were the same as the ffr mufflers regardless of their 6 inch extra length. With that said, they did sound more mellow at cruising speed, but sounded the same going up hill and while at full throttle.
FFR vs Sweet-thunder
sitting still in the car before 101 after 98dbs
standing 3 feet away from the car-either side
Before 102 After 96dbs
Behind the car-93dbs
2000rpm in 4th before 105 After 102dbs
2200rpm in 4th Before 107 After 104dbs
2500rpm in 4th Before(never tested)After 106dbs
2.5" internal diameter Classic Chambered mufflers(26" long)
NO difference over ffr exhaust.
<img src="http://i20.photobucket.com/albums/b218/corbrastang/cobrapackdyno.jpg">
And my final exhaust data is inconclusive till tomorrow, but i do have videos of a much improved sound. The inserts were made and installed by www.sweet-thunder.com and they truly replicate that of the mid-year vettes while quieting down the db level.
Video 1
http://s20.photobucket.com/albums/b2...ravideo003.flv
http://s20.photobucket.com/albums/b2...ravideo002.flv
I also tested the gas-n stainless pipes. They were just as loud if not louder than the stock FFR pipes, but were much prettier. The baffles were faced in the opposite direction so they did produce a flappy sound while coasting or downshifting. The same flappy sound was evident with all of the mufflers that had the louvers facing the direction in which the catch air, yet the db levels were only minimally reduced if any.
Old 05-30-2007, 08:19 PM
Pics
Factory five pipe
Classic Chambered
Length FFR vs Classic Chambered 26"cobrapacks
Classic Chambered installed(six inches longer)
Smaller diameter Sweet-thunder pipes that sound like sixties corvette pipes and reduce noise
Old 05-31-2007, 03:10 AM
BMK's Avatar
BMK BMK is offline
Some interesting comparisons
Bernie Knight
Old 06-19-2007, 08:26 AM
New dyno results are in for the Sweet-thunder pipes with the smaller diameter chambered mufflers when compared to the FFR 2.5 ID glassbacks. Baseline was 1hp less with the Cobrapacks.
We only lost 5 rwhp with the new exhuast-well worth the trade-off. The sound quality and volume is just so much better than any of the others that i have tested.
Old 06-28-2007, 06:30 AM
Rare Iron's Avatar
Chris - like you mentioned the Sweet Thunder cores were smaller - around 2-1/4". I could also produce the 2-1/4" core w/3" outer body & modified ends to slip inside a 4" straight pipe - same as my Corvette inserts that are also chambered with the crimps - called "POWERSTICKS." None of the Cobra owners so far are showing any interest in running actual chambered pipes. This would produce a quieter tone (with the 2-1/4" core), plus a different tone than the "Glasscraps" someone else is referring to most Cobra mufflers as. Basically, you are all running "glasscraps." Anybody up for a 2-1/4" flowpath chambered insert?
Old 07-01-2007, 09:31 PM
Burgs's Avatar
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
I have an interest! I ran the chambered exhaust on an '02 LS1, with SLP long tubes, and loved the sound! I sure would like to here what my BB FE might sound like with the crimped chambered set up.
Brad
Old 07-01-2007, 09:48 PM
CHANMADD's Avatar
I run glasspack non chambered straight through 3" id with a 4" body with 22" body on a 406 small block and it sounds great,especially at 7500rpm.It is actually pretty quiet at low rpm(I still listen to the stereo).
Old 07-02-2007, 09:41 AM
Cobra Make, Engine: ERA, Ford 428 SCJ
I'm installing sidepipes with nothing inside. Do you think it will be loud enough?
