Old 10-04-2006, 06:32 PM
Default Picture of a windshield-mount Raydot?
Anyone got one they can post? I'm looking to make a mount as I'm not wanting to spend $20.00+ for a flat piece of aluminum.
Thanks.
Old 10-04-2006, 10:26 PM
ROUSHAC's Avatar
Hope this helps!
Cheers!
Dave
Dave
Old 10-05-2006, 12:20 AM
Jamo's Avatar
Super Moderator
KISS School of Design...the Buckley Mount.
Jamo
Old 10-05-2006, 04:52 AM
Jamo,
Mirror from Motorsports Intl?
Old 10-05-2006, 09:16 AM
Jamo's Avatar
Super Moderator
Yup. Make double-doggone sure they know whether the mirror(s) is for left, right or center mount before they use the dye. Sounds obvious, I know...but folks will surprise you.
Jamo
Old 10-05-2006, 09:23 AM
bnewell's Avatar
Cobra Make, Engine: Kirkham 427FE (sold & missed)
do you have a part # or website for them??
thanks,
Brian Newell - Superformance Sales
Mansfield Motor Group
www.mmgauto.com
Old 10-05-2006, 09:34 AM
Jamo's Avatar
Super Moderator
www.motorsportsintl.com
Nothing there but contact info...ask for their parts binder. Pretty extensive. Just ask for the Raydyot mirrors. They used to require that you buy their mount as well. The Raydyot dye stamp is extra, but they are one of the few (if not the only?) ones licensed to use it in the US.
They also have a convex version for the middle mirror. Used to be Raydyot's own convex, which was perfect in that it tended to reduce headlight glare at night. However, I bought one for a friend a couple of years ago and it seemed like they had simply slapped in a Pep Boys convex into the body, which did NOT cut down glare at night.
Hope this helps in you seeing what's behind you...
Jamo
Old 10-05-2006, 09:44 AM
bnewell's Avatar
Thanks Jamo!!
www.mmgauto.com
Old 10-05-2006, 10:43 AM
Thanks Guys.
Old 10-05-2006, 01:06 PM
SuperHart's Avatar
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
OK, here's mine. I figured I couldn't let you guys have all the fun. I cut mine from a sheet of .125 aluminum after making a template. You will have to carefully countersink the holes for the screws that also mount the windshield. You will need slightly longer screws but do be careful that the screws are not too long or you could break your windshield. Of note is the fact that on the passenger side I had to end up bending the mounting bracket around 30* in order to get the mirror angled correctly so I could sight down the passenger side of the car. See the photos below.
DRIVER'S SIDE
PASSENGER SIDE
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Old 10-05-2006, 04:40 PM
terry lee's Avatar
GEAR GRINDER CUM LAUDE
Cobra Make, Engine: SPF #1560 w/ Ford Racing [RDI/AFR/RPM] Alum. 427CI - 575HP & TKO
Finish Line In Fla. Has The Alum. Mounting Bracket - That's Where I Got Mine.
Tl
BOYZ and TOYZ
With every day I grow alittle older -
BUT, I'LL NEVER GROW UP!
Old 10-05-2006, 05:47 PM
ROUSHAC's Avatar
Of course, you could just follow Raul Julia's advice as "Franco" in the movie Gumball Rally just before the start of the race:
"And now my friend, the first-a rule of Italian driving."
[Franco rips off his rear-view mirror and throws it out of the car]
Franco: "What's-a behind me is not important."
Cheers!
Dave
Dave
Old 10-06-2006, 05:02 AM
Cobra Make, Engine: Look-a-like cobra POS
For those you who would like to purchase the aluminum star adjustment knob:
MSC 1800 645 7270 / mscdirect.com
Star Hand Knob
1/4 - 20 thread
Pn: 76927060
Made in USA - $2.77.
B. Ewing
Old 10-06-2006, 08:18 AM
Cobra Make, Engine: CSX w/Shelby block
Just ordered a Raydyot mirror from Motorsports Int. including mounting bracket for $149. Seems pricely, but these guys appear to be the only folks who have the Raydyot logo on their mirrors.
Old 10-06-2006, 06:59 PM
Burgs's Avatar
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Just ordered the knobs,... Thanks Bret!
Old 06-10-2007, 02:18 PM
tc_sj's Avatar
Cobra Make, Engine: SPF#1751 CHP 427
Hi Jamo
Where did you buy the mounting bracket for your mirror, the on sale on finish line look a bit too big
Thanks
TC
Old 06-11-2007, 05:15 PM
Cobra Make, Engine: SPF 1421
If I mount a raydot on the wind screen, should I remove the 'factory' fendor one on my SPF? Would it look gay if I have two?
Joe S.-LI Lake Grove
