  #41 (permalink)
Old 06-19-2007, 11:48 AM
Chaplin's Avatar
Originally Posted by Roscoe
And believe it or not that is gelcoat. Eight years on the road and never been painted yet. Just the way it came from A&C.
Roscoe
I know it's still gel coat (because you're too cheap to get it painted) And it does look good.
Replica is not a dirty word.
  #42 (permalink)
Old 06-19-2007, 11:54 AM
Jamo's Avatar
Super Moderator
Here's some pics from down low...
Jamo
  #43 (permalink)
Old 06-19-2007, 12:02 PM
CobraEd's Avatar
Default A&C Gelcoat
And with the gelcoat A&Cs, if you put them upside down in the water, they will float.
________
________
  #44 (permalink)
Old 06-19-2007, 02:32 PM
Roscoe's Avatar
Now now Ed........Let's behave........Hey wait a minute.....if I had a 427 block in there I'd have my own boat anchor.
Roscoe
Roscoe
  #45 (permalink)
Old 06-19-2007, 03:06 PM
427PMS's Avatar
Premier Motorsports 427SC
Cobra Make, Engine: Premier Motorsports
Here is a pic of a Premier ( a later pic than previously posted ) with the changes that they did to the flares
  #46 (permalink)
Old 06-20-2007, 04:32 PM
FUNFER2's Avatar
Jamo- perfect stance ! Nice & level.
Kevin
  #47 (permalink)
Old 06-20-2007, 05:11 PM
Originally Posted by computerworks
Actually..there were three configurations of the rear shape:
The Comp cars and most of the street cars were what is known now as 'wide-hip'... broad rear wings with no flare.
The S/Cs had a 1-inch flare pounded into them before paint for street use, but they were Comp cars with wide hip to begin with
And finally, the 'narrow-hip' was a design change that lasted only for a few dozen street cars in the first production run. After they changed over to street production, they tried to minimize the size of the rear fenders, since the street-sized tires left a lot of "air" in the wheel arch opening. A few dozen were built that way...but it didn't look as good as the old way, so they switched back. The 'narrow-hip' had no flare either.
Actually there was a fourth shape, my car was a "wide hip" car and I ordered it with flared fenders, Shelby moved the outer surface outboard but did not add the SC right angle at the wheel opening. I don't know how many cars were done like this but I have had racing tires with a 13.5 " cross-section on with only slight contact with the square tube at the front of the inner fender.
I used to run the Goodyear transAm slicks that were used on Mustangs in the late 60's and early 70's. The rims were the stock factory 9.5" Hallibrands. I believe the tires were about 26.5 tall with a 12" tread and a 13.5 section width, they would probably rub on an original SC.. I would also caution against setting ride heights to get the right look, chassis rake angle has a major effect on roll couple distribution and can really cause major handling issues if it is wrong.
  #48 (permalink)
Old 06-20-2007, 06:04 PM
1985 CCX's Avatar
Could you add some photos to your gallery? I am sure it would be appreciated by more than myself. Thanks......
CCX rear end: I am running 26.5 x 10.5 Goodyears on the back and it does not rub at all.
All I did was adjust the ride height down a smidge! Looks very original when standing next to CCX with the standard ride setting.
  #49 (permalink)
Old 06-20-2007, 07:15 PM
Thumbs up jamo
how much did you lower your car it looks great.
  #50 (permalink)
Old 06-20-2007, 07:30 PM
Chaplin's Avatar
Until he sits in it
  #51 (permalink)
Old 06-20-2007, 07:33 PM
computerworks's Avatar
Originally Posted by redd
Jamo - how much did you lower your car it looks great.
Chappie...I purposely wasn't touching that line....
  #52 (permalink)
Old 06-20-2007, 07:35 PM
Chaplin's Avatar
I'm not opposed to picking low hanging fruit!
  #53 (permalink)
Old 06-20-2007, 08:50 PM
Danr55's Avatar
An older Contemporary. Much like Jeff's car.
Dan in Arizona
CCX3209
  #54 (permalink)
Old 06-21-2007, 12:31 AM
Jamo's Avatar
Super Moderator
Chappie, Ron...you can both bite my a$$.
Jamo
  #55 (permalink)
Old 06-21-2007, 12:54 AM
Default Pictures
Originally Posted by 1985 CCX
#3170
OK, pictures are posted, thanks for asking. 26.5 is a good diameter I have to run 25" diameter to get the width and compound I want but would prefer 26.5
I run a 25x12.5x16 in the rear and a 23.5x11x16 in front
  #56 (permalink)
Old 06-21-2007, 04:24 AM
1985 CCX's Avatar
Thanks for posting some pics, it is always great to se another early car.
Chappie,
You are right, I don't add to the looks at all.......LOLOL
Jeff
  #57 (permalink)
Old 06-22-2007, 02:47 PM
greg schroeder's Avatar
I've only seen a handful of original Cobras, three in person and maybe a dozen on line. It seems they have all sorts of shape fenders and lips on the rear. One I remember even had both sides that looked diffrent from each other.
I'm pretty happy with my Superformance look.
  #58 (permalink)
Old 06-29-2007, 06:22 AM
The truth to the Cobra body shape is that they were all "rough beaten" and even each side wasn't identical. Each model was different and each modified version didn't have the same shapes. SO.... your Cobra is unique just like the originals. (as long as you don't add wings or pointy bits ! )
  #59 (permalink)
Old 06-29-2007, 07:02 AM
TButtrick's Avatar
FUNFER2,
If you're on a budget, Hurricane Motorsports will give you the best bang as far as accuracy vs. price.
  #60 (permalink)
Old 07-16-2007, 07:18 PM
double ugly's Avatar
No one bought Hi Tech after Tim Gunning went bankrupt in the 90s. A new company in Texas is the 21st century Hi Tech using a carbon Fiber body with very accurate detailing. Roger Bolick is the owner of the company and isn't giving any information yet re: the name of the company.
double ugly
