Old 06-19-2007, 06:44 PM
Default Engine Mounts
My B&B did not come with any mounting points on the chassis for the engine. Is there anything I can buy at NAPA that will bolt on to the chassis so I can install my engine with the correct motor mounts? I do not want to wait for an order to come from the states, I am in Canada. I am also trying to avoid welding.
Thanks,
Corey C
Old 06-20-2007, 06:58 AM
Wayne Maybury's Avatar
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
Corey
Unless I am mistaken, you are probably going to have to fabricate something and welding may be necessary unless the chassis already has some sort of base on which the mounts can be bolted.
Depending on how far you are away from the border, the easiest thing to do is to get the parts you need, sent to a company that specializes in receiving and sending packages (they are usually located right at the big border crossing points). Go to the US, pick up your parts and bring them through Customs yourself. Of course you should declare the parts when clearing Customs but it is quick and easy.
Wayne
Don't get caught dead, sitting on your seat belt.
