Old 06-22-2007, 06:40 AM
Cool questions on how to decode orginal 67 cobra
trying to figure out how to decode possible original 67 cobra,what engine options,carb and transmission and body tags
Old 06-22-2007, 06:47 AM
computerworks's Avatar
Be a little more specific and we can help...
Are you asking where to look for s/n stampings, etc?
What is it you are trying to I.D.?
Old 06-22-2007, 07:03 AM
Power Surge's Avatar
Not much to "decode". All there is, is a VIN plate in the footbox. The VIN will tell us what car it is (example- CSX3302). From there, we can check the registry and tell you all the known info on the car. Motor wise it would be either a 427 or 428, which could be told from what VIN the car is, and the trans would be a 4 speed toploader.
Also, pictures would help as well. Especially for us to see if it's an actual Cobra or just something else registered as a 67 like 99% of the cars people think are originals.
Sal Mennella
Old 06-22-2007, 11:39 AM
Murphy's Avatar
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Default EZ way to tell for starters
Check if the body is aluminium or fiberglass.
Old 06-23-2007, 08:52 AM
Default 67 cobra
there is a possible chance i may have loacted an original 67 cobra.
by the way thanks for the quick replays guys
Old 06-23-2007, 09:02 AM
mrmustang's Avatar
Gold Star Contributor
As stated above, post the VIN when you find out what it is, also post any other numbers you find. Casting numbers of the engine block, heads, intake manifold. Check the VIN as found on the title and older registration and again post them here. Pictures of the body, engine compartment, trunk, and if possible front and rear suspension and frame rails will go a long way toward true identification. PICTURES ARE IMPORTANT!!!!!!!!!!!!!!
Bill S.
