Old 07-03-2007, 02:01 PM
Cobra Make, Engine: 351 Windsor
Default Side pipe question?
On the side pipe cut out on the body. How much space is required between the side pipe and the top of the cut out section? Thanks
Old 07-03-2007, 03:06 PM
Terry Stapley's Avatar
Cobra Make, Engine: Shell Valley, 418W, tremec 3550tko, 9" ford rear, 3.0 gear, silver/black
I think that spacing would vary a bit with different horsepower ratings and various engine mounts. I have about 3/4" clearance and the sidepipes have not touched the paint yet.
Terry
Old 07-03-2007, 03:32 PM
Banned
Important Tip: Retarded timing raises the exhaust gas temperature considerably. When performing an initial start on a newly painted car, or when installing a new/rebuilt engine, make sure you advance the timing and run a little richer fuel/air mixture. Also, point some portable fans against the sides to help with heat dissipation. This will keep exhaust temps down and avoid blistering the paint.
-Dean
