Old 07-31-2007, 07:13 AM
Cobra Make, Engine: SPF 2473, Roush 427R
Default Best glue for bonding roll bar grommets
What's the best adhesive to use when bonding the rubber roll bar grommets to the painted body on my cobra? I tried Permatex contact cement and Loctite epoxy. Neither worked.
Old 07-31-2007, 07:30 AM
mickmate's Avatar
Adhesive? Don't you just drill the right size hole and the bar OD holds the grommet in place in the hole?
mickmate
http://www.actoncustom.com/
Old 07-31-2007, 07:54 AM
CobraDan's Avatar
If you used a contact glue it is rubber cement and needs to be applied to the bottom of the grommet and also the painted surface and then let to dry before you place them together for a bond.
Dan Wulff
Old 07-31-2007, 08:32 AM
Ron61's Avatar
Post
I never used any glue for my grommets. They fit the holes well and had the regular grove like a smaller grommet that you put wire through and when the roll bar was stuck through, it pushed them tight.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 07-31-2007, 08:36 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
They use superglue at the factory (leaves a residue on the body)...but I used two sided sticky tape...and had no problems...plus it's easily removable if I go back to the shorter roll bar.
Old 07-31-2007, 09:12 AM
Cobra Make, Engine: JCF supplied the body,frame,and some of the driveline-I completed it to be a very accurate 289 slabside
Goop for plumbing has become one of my favorite adhesives for difficult to bond materials like rubber and plastic. Mask off anything you don't want it on.
Old 07-31-2007, 11:04 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
If you need an adhesive, try the 3M weather strip adhesive. This is sometimes called "yellow snots".
It is nasty and I would not recommend it get on anything you are not bonding.
Works well and will probably do the trick.
Old 07-31-2007, 10:03 PM
GlynMeek's Avatar
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
Why not spend $45 for the set from Finishline and then you can just bolt them in rather than dicking with glue?
http://www.finishlineaccessories.com...feab38e3537b3b
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
