January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 08-15-2007, 04:42 PM
Frank Messina's Avatar
Cobra Make, Engine: FFR, V8, Manual Trans, Htr, Wipers, Radio Delete
Did you try Mike Forte 508-875-0016?
Frank
Old 08-15-2007, 07:29 PM
Dan Semko's Avatar
Hoosier Gashole Emeritus
Look on the drivers, upper side of the transmission. There will be two wires
(on the older versions and I believe 3 on the newer)that loop towards the rear of the trans. If you want to over ride the neutral lock out, cut the wires from their attachments and bridge them together with a connector. If it has the 3 wire, wind the wires together and test the neutral start before you permanently connect them.
DDS/The First Edition
"In debates on ethically contentious issues, it is never wise nor polite to deride or belittle another person's delusion."
Old 08-15-2007, 07:38 PM
Cobra Make, Engine: SPF 545" stroked 460 - sold
The 3550 and TKO 500-600 series apparently use the same neutral safety switch, at least when I was looking into this a while back. Info source and parts source try Jimi at http://www.standardtransmission.com/
Display Modes
