Old 08-20-2007, 10:55 PM
tc_sj's Avatar
Cobra Make, Engine: SPF#1751 CHP 427
Default Help with Battery Brain connection
I purchase a battery brain type III (remote anti theft disconnect), since there is no room to connect this module in the battery enclosure in the trunk, I deciced to connect it right at the firewall near the connection of the starter, I was able to start the car fine but not able to disable the battery by using the remote control
While I press the remote control I hear a click at the module and the battry still connect
Any folks has hooked-up this successfully, please share some advice
I plan to call customer service tommorrow
Tan
Old 08-21-2007, 08:03 AM
CobERA's Avatar
Cobra Make, Engine: ERA #644 428 FE
Tan,
If I remember correctly, the side of the Battery Brain that says "Batt 12v+" would normally be connected directly to the positive terminal of the battery, and then the positive battery cable would be connected to the other side of the Battery Brain.
I can't quite make out from the picture how yours is wired, but I think it may be backwards. To make it work (I think) you should attach the positive cable coming directly from the battery to the "Batt 12v+" side of the Battery Brain, and then attach the other side of the Battery Brain to the stud on the starter solenoid. However, I know on my car, there would be some clearance issues if I tried to mount it where you are.
I am not familiar with the SPF battery trunk mount, but is there not some room on the side of the battery or on top?
ERA 644
I'm getting old too fast and smart too slow!
Old 08-21-2007, 03:27 PM
tc_sj's Avatar
Thanks Rick
Yes, I did have the battery brain hooked backward, I fixed and now I can enable and disable the battery by remote, I talked to the tech this morning and he told me the black wire must be install for "remote anti theft disconnect" but I still can not get it to work, he will need to check and get back to me
The question I have for the black wire refer to "disable connection / engine on wire installation"
http://www.smgy.net/batterybrain/dow...install_us.pdf
Tan
