Old 11-03-2007, 09:15 PM
Juggernaut's Avatar
Cobra Make, Engine: RUCC, 289 c.i. with a T-5 "Living the Cobra Experience"
Default CNC Slave Cylinder Question - Please Help!!
Hoping someone can help me with this one as so many forum members has helped me out before.
I need to get a bracket to mount my CNC push type slave cylinder to the side of a 1984 T5 tranny so it pushes the fork forward, does anyone know where I can get a bracket?
I did a search on the subject but wasn't very successful.
Thanks in advance,
Randy
Juggernaut
Old 11-04-2007, 01:32 AM
Cobra Make, Engine: Superformance Brock Coupe
Check out any good racing team in your local area. Someone on that team has to know a good fabricator. A really good bracket that is properly measured an built correctly could easily take two hours. At $80 an hour the bracket should cost about $160 bucks. Expensive? yes, but done right you won't have any more problems. Badger
Old 11-04-2007, 04:18 AM
Cobra Make, Engine: unique 427 302/300hp t/5
Default T-5
THE BRACKET THAT YOUR LOOKING FOR IS AT WWW.DAZECARS.COM IT'S ABOUT 55.00 DOLLARS PLUS FREIGHT . REMEMBER YOU STILL NEED THE PUSHROD AND HALF MOON WASHER AND GOOD RETURN SPRING .I HOPE THIS HELPS I USE IT AND IT WORKS PERFECT. HOPE THIS INFO HELPS YOU. IF YOU CANNOT FIND IT EMAIL ME .
Old 11-04-2007, 04:59 PM
Juggernaut's Avatar
Thanks guys for the responses!
COBRAGEAR - I'll be contacting Daze Cars for the bracket I need.
Once again, thanks for the help. Another problem solved!
Randy
Juggernaut
Display Modes
