Old 11-26-2007, 01:47 PM
TButtrick's Avatar
Default spinner wrench
anyone use one of these? comments? does it work with an impact wrench?
Old 11-26-2007, 02:11 PM
Nedsel's Avatar
Original Shelby Owner
Got one last year. I'm still trying to figure it out.
Ned Scudder
Old 11-26-2007, 02:15 PM
Cobra Make, Engine: owned Kirkham for 11 years
I haven`t used mine yet,but I believe you just use a long pipe in the end.
Maurice
Old 11-26-2007, 03:03 PM
wtm442's Avatar
Beam Me Up Scottie
If you want one, I'll sell you mine.
It will not work with an impact wrench.
Warren
Old 11-26-2007, 03:25 PM
Kramer's Avatar
Cobra Make, Engine: ERA 739
never used one, however I heard they don't work. I even met a gentlemen that milled one out of raw aluminum to use with a rachet and could not get it to work right...and this guy works at a superformance dealer. A buddy mine (also a cobra owner) went to purchase one and he talked us out of it.
Old 11-26-2007, 04:17 PM
bnewell's Avatar
Cobra Make, Engine: Kirkham 427FE (sold & missed)
I use mine as a paper weight........looks nice on my desk.
Brian Newell - Superformance Sales
Mansfield Motor Group
www.mmgauto.com
Old 11-26-2007, 04:18 PM
xracerbob's Avatar
I'm going to try and make one using a large diameter impact socket by milling out 3 windows for the ears and filling the inside of sthe socket with Devcon so it will match the profile of the spinner. I don't think a 1/2" impact wrench will do it so I'm going to use a 3/4" drive.
We'll see how it works. I won't have my car for a couple more months, so patience is required .
Old 11-26-2007, 04:55 PM
Kramer's Avatar
Xracerbob..I have seen something just like you are referencing...again, the head wrench at our superformance dealer created one from a solid piece...and still wouldn't recommend anyone in his shop trying to use it.
Good Luck...be interested to hear the outcome.
Old 11-26-2007, 05:09 PM
A three foot piece of pipe and then you tighten it up with those little doo-hickeys that you would use if you ever lifted free weights. Here's a shot:
Old 11-26-2007, 05:11 PM
Kramer's Avatar
looks nice...does it work?
Old 11-26-2007, 05:16 PM
Yep, with one hand on each end you can put a heck of a lot of torque down on it. Remember to use anti-seize when putting the spinners back on and don't keep pounding with the hammer. After a whack or two the sound changes; that's your cue to stop -- then safety wire.
Old 11-26-2007, 05:26 PM
JBo JBo is offline
Cobra Make, Engine: Ex CSX3327, & AK7113 AutoKraft AC MK IV
I have used mine once to remove a severely jammed knock on on my AK. Worked like a charm. Not a pretty a set up as the 2 prior emails, used a small diameter steel bar through the bars, leaned into the boss with my knee and one up/one down. Did have to mind the bar slipping in the through holes though. Antiseise, appropriate use of hammer and safety wire means never having to use it again I hope. AK guys in England have made up one by cutting slots in a 3" steel socket and fitting a breaker bar. I would be careful with a 3/4" impact...although I had pounded on one ear so hard it had to be the equal of that.But the impact is going to put rapid repeated blows on the knock on simutaneously on all three ears, but I'm not an engineer.
Old 11-26-2007, 07:12 PM
TButtrick's Avatar
Thanks for the replies all. I'll stick with the lead hammer. Put anitseize on the mating surfaces of the spinner and wheel as well... right? I just galled the sh!t out of one my new spinners. DUH!
Old 11-26-2007, 07:18 PM
xracerbob's Avatar
The pin drive wheels we used on the race cars used one large nut in the center that was approximately the same size thread as the knock off. The torque spec was 450 ft/lb if I remember right. A 1/2" impact could conceiveably do it, but it would be easy for a 3/4" tool. (I've been involved with these things since 1980).
Of course I could always go up to the BIG tool:
http://www.irtools.com/IS/product.asp-en-2916
3.5" square drive, 80,000 ft lb, $49,500. Sockets start at about $2,000 ea.
Old 11-26-2007, 07:53 PM
Cobra Make, Engine: Cardiac, 428 FE
It would be far better to anti-seize the threads and mating surfaces, whack it a few times to tighten, then safety wire it on. Getting it off is much simpler with a lead hammer than boogering it up with that socket thing.
I'll have to admit that the big pipe thingy that patrickt showed us looks much better than the 3/4" impact wrench though. At least with that you would be able to tell when you've put too much torque on the spinner.
Lead hammers have worked just fine for years. Used a small one on my MG in the 60's.
Paul
Old 11-27-2007, 07:22 PM
chopper's Avatar
Cobra Make, Engine: Previous ERA owner on break
This comes up periodically. Here is an old thread on the subject. FTR, if I hadn't had that wrench, I'd probably still be trying to get the spinners off the car.
Aluminum vs stainless steel wheel spinners
Some folks drink from the fountain of knowledge; others just gargle.
Yesterday's flower children are today's blooming idiots.
