December 2025
Old 01-20-2008, 03:44 PM
767Jockey's Avatar
Default What are you using for rear rollbar tube grommet?
I just installed my rear rollbar tube. I tried using a slit fuel line slit lengthwise around the unfinished oblong hole, but I don't like the way it looks. It's too heavy and bulky looking. I don't want to just leave it untrimmed. Is there any light thin "U" channel type stuff any of you have used and can recommend? I've seen the stainless and/or aluminum and rubber type grommets that are sold that mount above the rear deck of the car and I don't want to go that way. I'd like something rubber that wold be used similar to the slit fuel hose method, just less bulky and neater looking.
Old 01-20-2008, 03:50 PM
Ibr8k4vetts's Avatar
Finish Line Accessories
Mike Z
Old 01-20-2008, 04:41 PM
1985 CCX's Avatar
Doug,
Via Cobra Restorers:
For strut opening, use split vacuum hose and knife edge body.
I use nothing as the hole is clean and neat anyway. You are repainting so why not edge and smooth. The paint will create a nice rolled edge look and stay with the theme of these cars "Utilitarian".
Rubbers are overated anyway!
Old 01-20-2008, 05:17 PM
767Jockey's Avatar
I like the look of a clean edge and no rubber. Unfortunately the hole turned out to be just a bit larger than I wanted. It's not bad at all, but is a bit larger than yours. Also, for reasons I don't understand, the paint chipped a bit around the edge. I was real careful with it, made sure I used a fine tooth hole saw from the top, etc, but it still chipped up a bit.
Mike, the ones from Finishline mount on top of the deck, not was I was looking for. Thanks for the info, though - I appreciate it.
Old 01-20-2008, 05:32 PM
Silverback51's Avatar
Go to the link below and type in "Edging", or go to page 3655 for Edge Trim. They have a lot of other types of trim also.
McMaster-Carr
Old 01-25-2008, 09:18 PM
partsman's Avatar
Cobra Make, Engine: FFR 347carb
Got this in the mail at work. Looked interesting. Never used it myself. Trim Lok - #1 Source for Plastic and Rubber Trims and Seals
Old 12-14-2009, 07:36 PM
mickmate's Avatar
Slit tube super glued together at the ends.............
mickmate
http://www.actoncustom.com/
Old 12-14-2009, 08:37 PM
Bernica's Avatar
Senior CC Premier Member
This is what I used from Finish Line....
Old 12-14-2009, 08:44 PM
mickmate's Avatar
I've also used them but only when someone had done the hole before me and I needed a big cover up. That back one is a trick with them isn't it?
mickmate
Old 12-14-2009, 08:58 PM
Bernica's Avatar
Yes, a trick to be sure. Catching enough meat for the srews and working with an oblong hole.....Someone else had made them too big, so that's the route I went. Looks like my pic didn't come out. It's in my gallery if someone needs to see it.
Old 12-14-2009, 10:25 PM
Rick Parker's Avatar
Thin wall radiator overflow tubing (plain rubber, non re-enforced) works very well. Slit it in a straight line.
Rick
