Old 02-02-2008, 01:56 PM
Mdman352's Avatar
Cobra Make, Engine: Contemporary-427 stroker
Default cleaning aluminum
Greetings. I need some advice as to what to use on two different aluminum parts on my Contemporary Cobra.
1. The engine compartment has aluminum panels sparating the engine from the running gear. They are a little grimmy and I would likee to get them clean with out ruining the surface shine.
2. I have the cast aluminum "Cobra 427" valve covers and they as well as the manifold and the water pump are gross!!! Dirt, grime, rust, fuel staining.....
These covers were in a wash cabinet with 180 degree water first then I have tried: stuff for cleaning aluminum semi trailers, Simple Green, Ajax, oven cleaner (worked pretty good).....
I am heading towards getting them bead blasted but not with the cut glass, using balls instead. Can anyone suggest something that will clean these items?
Thanks.
David
Old 02-02-2008, 02:40 PM
Cobra Make, Engine: Midstates, Genesis 427 S/O
David,
The best aluminum cleaner and polish I've used is Blue-Job (blue-job.com). You can find it at most Harley shops.
Chris
"God saved you by His grace when you believed. And you can't take credit for this; it is a gift from God".
Ephesians 2:8
Old 02-02-2008, 03:54 PM
double ugly's Avatar
Sounds like bead blasting for the cast pieces is the way to go. I did that on a Sunburst cast alum. rim then used WD40 to protect the finish. On the aluminum panels after they're cleaned try Magic Aluminum Polish
John
double ugly
Old 02-02-2008, 04:05 PM
1985 CCX's Avatar
Dave
I use windex, and scotch brite as I am going for the old look. WD40 is also a good route as it cuts grease and protects.
Add somne pics to your gallery.....
Remember to use the Contemporary Forum within this site.....
Jeff
Old 02-02-2008, 04:20 PM
Dan Semko's Avatar
Hoosier Gashole Emeritus
I used Windex and Scotchbrite initially to clean the surfaces on my aluminum CSX's and sealed the surfaces with Zoop Seal. The trick with Zoop Seal is using a little rather than a lot and avoiding overlapping applications.
Afterwards, grease, road dirt, tar etc easily wipe off with either Windex or Dawn dish soap.
DDS/The First Edition
"In debates on ethically contentious issues, it is never wise nor polite to deride or belittle another person's delusion."
Old 02-02-2008, 07:56 PM
Mdman352's Avatar
Question Photo posting
I have tried to post pictures to no avail. can some one help me??
David
Old 02-03-2008, 06:32 PM
RACERAL's Avatar
Cobra Make, Engine: Factory 5 mk4 445 FE
Try this stuff.. On my Halibrands.. when the cast alunimum gets a little dingy, I spray this stuff on and it makes the cast aluminum look brand new. Now, it will make polished surfaces look dull and you have to shine them up..
Mag Cleaner
Thanks,
Al Adkins
Stoneville,NC
My ex car. Sad to see it go.
http://www.ffcars.com/POM/nov2003pom.JPG
Old 02-03-2008, 08:19 PM
RedCSX1's Avatar
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Aluminum panels- dawn dish soap
Cast aluminum - Simple green or engine degreaser. Do no use mag cleaner!
Morgan LeBlanc
Fresno CA
Old 02-04-2008, 06:43 AM
PatBuckley's Avatar
I used regular car wax on mine.
Old 02-04-2008, 07:01 AM
cobrarkc's Avatar
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
For any polished surfaces I have used Simi-chrome polish works great. You can usually get it at a motorcycle store.
Cobrarich
Old 02-07-2008, 12:38 PM
Mdman352's Avatar
Default nothing worked
I have bought a blast cabinet and will use glass beads as they clean better than the other media like walnut hulls. NONE of the mentioned products worked. I have a really dirty set of valve covers, manifold, etc. as the car has been idle for 15 years. thank you all for you suggestions. i will take some before and after pictures.
David
