December 2025
Old 02-26-2008, 11:36 AM
chuckbrandt's Avatar
Club Cobra Member
Cobra Make, Engine: ERA # 665, 390 (to start with) Toploader
I had a worse problem, once hot and sat for a while, you'd start the car and gas would dribble out the bowl vents and kill the engine. I have a holley insulating kit installed now, but mostly you need to mix some race gas in with winter gas. A couple of gallons of 100 octane per tank seems to do it for me. I don't have the problem in the summer.
Chuck
Here is a picture, you can see the heat shield under the carburetor.
Build website at www.chuckbrandt.com
Old 02-26-2008, 11:47 AM
Cobra Make, Engine: SPF #1019
Originally Posted by chuckbrandt View Post
...I have a holley insulating kit installed now...
I just installed the same kit last weekend, however I installed the phenolic under the heat shield, not on top of it. My theory is that I want the heat shield not to absorb heat from the manifold and radiate it to the float bowls.
Old 02-26-2008, 12:10 PM
Club Cobra Member
Default I tried that
I tried that but my accellerator pump arms would hit the tin. So I switched it. If it works for you that's probably prefered.
Chuck
Old 02-26-2008, 12:15 PM
Chuck
Yes, my pump arms hit as well, so I used my dremel to cut small slots in the shield to make room <- actually, scootter told me about this a while ago, so I take no credit here
I'm not sure yet if it works, since I have not had an opportunity to enjoy our recent "spring-like" weather. I plan to driving to breakfast this Saturday, so we shall see (smell) if it works...
Old 02-26-2008, 08:39 PM
Cobra Make, Engine: Superformance, 392 W
I too had the same problem and it was most definetely fuel boiling in the carb after shutting the engine off. I lowered the float levels and installed a half inch plastic spacer purchased from Jeg's( I preferred the black color rather than the typical redish phenolic spacer ).
JEGS CNC Poly-Billet Carb Spacers - JEGS
I have not had an issue since. I was running the cooling fans manually for around 5 minutes as a temporary fix until I installed the spacer and still do so when I park it in the garage.
Display Modes
