Old 02-27-2008, 05:15 PM
Cobra Make, Engine: Butler Racing/427 side oiler
Default Can ya help me ID this rear
have a Jag rear and cant seem to ID it ...I cant seem to upload pics right now either but there are the numbers
G
then 4HV 004
does this make any sense?
Ill post pics when I can
Old 02-27-2008, 06:50 PM
David Kirkham's Avatar
Original Shelby Owner
Post the pics and I imagine we could help.
David
Old 02-27-2008, 06:59 PM
mickmate's Avatar
Does it have any tags on the back cover bolts?
mickmate
http://www.actoncustom.com/
Old 02-27-2008, 07:00 PM
capteddie's Avatar
Cobra Make, Engine: CRII 351W/408 Stroker
Send a message via AIM to capteddie
Hold on a sec and I'll check it out
Ed
Old 02-27-2008, 07:58 PM
cobrajam's Avatar
Cobra Make, Engine: Contemporary frame, Midstates kevlar body, Aluminum Shelby 427, G-force T-5
When I was communicating with I believe his name was Mike at CWI, he told me the casting number were worthless for the most part. He wanted a physical description of the outside, seems a primary difference is the number and pattern of the reinforcement ribs on the outside. Below is a pic of the exterior of mine which turned out to be most likely from a mid-80s XJS with tapered bearings, and was actually a Dana. The way he talked, the only real way you identify them was open them up. The stamped tag bolted to the rear cover is helpful in identifying the ratio, as well as if it is an open or a BPL PowrLok diff.
Old 02-27-2008, 08:28 PM
Much better ..heres the pics. It is a posi and I do believe a
Dana Locker JAGUAR rear end with an axle ratio of 3.54-1
Old 02-27-2008, 08:30 PM
I just wish I knew what I was looking for when it comes to brake parts and options for such ?
like what year this is etc?
Old 02-27-2008, 08:45 PM
767Jockey's Avatar
Solid rotors, Girling calipers, looks just like my E type series II setup.
Old 02-27-2008, 09:28 PM
cobrajam's Avatar
See how it how it has the 3 thinner ribs on the drivers side versus the one really thick one on mine. I think that is what he described as being the pre 68-69 E-type. Looks relatively clean and complete, even the rotors look to be close to the full thickness.
Old 02-27-2008, 09:32 PM
767Jockey's Avatar
Early "E" types (Series I) had the Dunlop calipers with the bolt on aluminum pistons in cast iron frames. These are the one piece aluminum Girling calipers, they're Series II pieces.
Old 02-28-2008, 07:52 AM
Tom Wells's Avatar
All,
I found information put together by Street Rodder and Mike Bontoft in April 1995. The scanned article is here: First Coast Cobra Club • View topic - Jaguar differential decoding
It's a pretty complete reference to identification of the various Jag/Jaguar rear differentials, brakes, axles and hubs.
Hope this helps,
Tom
Old 02-28-2008, 08:33 AM
Thanks alot Tom
Last question..if a guy needed brake parts ..would they be available locally or am I looking at ordering from somewhere?
Old 02-28-2008, 09:36 AM
CHANMADD's Avatar
An easy way is the front input flange on the Dana is the square one and the round flange is the Salisbury. Also the Dana Discs have to have two holes in them in order to facilitate removal.
John
Old 02-28-2008, 10:08 AM
so mine is salisbury then
