Old 04-03-2008, 12:06 PM
Default Exhause flanges
Hi, can anyone help? I am looking if there are drawing available of the exhause flange to bolt on my AFR 185 heads. I need to have them made here and make my own headers.
Thanks, regards from Sweden
Old 04-03-2008, 01:20 PM
greg schroeder's Avatar
You might be able to use the AFR recomended gasket.
off idle drag pass, DA 750ft.
Old 04-04-2008, 09:11 AM
That may be an idea, I was thinking to find an AutoCad drawing so I can have the steel flanges cut out by waterjet
Old 04-04-2008, 10:31 AM
Do the AFR heads have a narrow and/or wide bolt pattern? I've got a drawing derived from a set of Earls gaskets with the narrow pattern. Port size 1.62"H x 1.125"W.
If you give me the port size and its relationship (height-wise) to the bolt holes, I might be able to whip up something.
Old 04-04-2008, 07:37 PM
Cobra Make, Engine: jbl
185's have the narrow standard ford bolt pattern, 205's & 225's have both standard and wide.
Old 04-05-2008, 11:55 AM
I will chech the bolt pattern and port size tomorrow. I apriciate all your inputs hope we find a solution.
Anybody else fabricating their own headers??.
(Got a parts shipment from Summit and my wheels today, spring is here!)
Old 04-06-2008, 11:37 AM
The port size is W 1.33" by H 1.37" bolt pattern is 2". I measured in milimeter and converted to inch.
Old 04-06-2008, 03:34 PM
Is the port centered vertically on the bolts?
With only 0.335" between the edge of the port and the center of the bolt, there isn't much room for a wrench. Generally, even with the narrow port, the tubing flares out from the port but is dented in to clear the bolt head.
Old 04-07-2008, 01:15 AM
Thanks for the input. No it is not even centred, I am on travel a couple of days but will take more measurements and photo diring the week
Old 04-07-2008, 06:33 AM
Have you checked to see if AFR, Summit, or Jegs (among others) may sell the flanges? I have a friend who can probably sell you the flanges with stubs attached if you would like to go that route?
Old 04-07-2008, 08:10 AM
Bob, I have not checked by Summit or AFR. Keith Craft have build my engine, the heads are CNC machined so I am not sure if the port size is standard. how much do your friend ask for e set?
Old 04-07-2008, 08:30 AM
Stephan,
I would need to know the exact size of your ports and relationship to the bolt hole location to see how much machining he would need to do to a standard set. A good chance the standard set will fit with little or no machining. I will check with him today and get back to you.
Old 04-07-2008, 08:33 AM
Originally Posted by Three Peaks View Post
Stephan,
Thanks, will try to measure more exact
Old 04-07-2008, 08:51 AM
1Cobrat's Avatar
Cobra Make, Engine: Scratch built Bowtie, C4 suspension, Fiberjet body, 427 Rat
I used a local exhaust supplier to help me fab my exhaust system. they do outstanding work. I/m sure if Chris doesn't have it he can point you in the right direction. Here is the link to his site
http://www.spdexhaust.com/HomeB.html
Let me know how it goes.
Old 04-07-2008, 10:09 AM
Stefan, PM Sent
Old 04-10-2008, 12:10 PM
I try to enclose a photo for you, but my images are too large to publish here. I will find a solution.
