| 29 |
04-10-2008, 05:42 PM
Rubber side pipe mount?
Does anyone offer a purpose built rubber mount that fits between the side pipe mounting pad and the frame? A round disc type motor mount 1/2" to 3/4" thick and a stud on each side would work great.
Dave
Too many toys?? never!
04-10-2008, 05:57 PM
Fl
There is a local rubber company here in town that carries them. I don't recall the price, but it wasn't outrageous.
04-10-2008, 08:12 PM
ont
Undy,
I went to my local truck spring rebuild shop & looked thru their inventory of large rear spring rubber bushings untill I found 1 the O.D. & I.D. I wanted.
Took it home & sliced off 3/4" spacers from it. They have worked great for 3 years--15000 miles.
You don't need special silicone etc. material, they don't get hot enough to require it.
Craig
04-10-2008, 08:43 PM
tx
Mine ae hung with rubber exaust hangers. You can get them at any auto shop.
" It ain't no big deal"
04-10-2008, 08:55 PM
Fl
I have heard of a lot of folks using sway bar end links.
04-10-2008, 10:38 PM
Some chunks of old car tire sidewall provide some free padding...
04-11-2008, 03:28 AM
Mr Google is my friend...
http://www.mfgsupply.com/m/c/MM-101C.html?id=8v7665if in my case..
http://www.mfgsupply.com/SnowMounts....on_id=8v7665if for others with different spacing requirements.
A bolt through a rubber bushing, end link or piece of tire still has a metal to metal link, hence the through bolt. I wanted 100% isolation as these low cost units have.. I'll buy 4 and squirrel them away for future isolator failures.
04-11-2008, 03:42 AM
The small truck mounted generators and refrig units have vibration isolator mounts. Unconnected threaded studs sticking out of rubber cylinder. Try a Kubota deisel dealer.
04-11-2008, 05:51 AM
I used polyurethane suspension components, picked the appropriate size from the display at a Race Shop
http://www.energysuspension.com/
04-11-2008, 05:52 PM
Cobra Make, Engine: ERA - 427
Search mcmaster.com for "vibration damping mounts"
Hundreds to choose from - different sizes, durometers, and materials
04-11-2008, 05:58 PM
heavy hauler
Cobra Make, Engine: Shell Valley stroked 342
I just used belting like they use on conveyors
I Planted...Watered....But God gave the increase....
