December 2025
Old 05-11-2008, 06:30 PM
Cobra Make, Engine: D&D Cobra,302 stock for now,IRS
Send a message via Yahoo to michel schryer
Unhappy Need to install a tank vent,suggestions please !
My gas tank came with no vent system,i'm concern about a lock in the system and i would like to make some kind of venting system. All i have is a small 90 degee elbow on the side of tank and the hole at the bottom to install the fuel line to my mechanical pump.
I have very small space between the top of the tank and the trunk sheet metal piece,only 1 inch. I don't want anything to protrude in the trunk so how could i do that. I can't and don't want to weld nothing.
Any body facing the same situation,what can i do ? Thanks !
Michel
Old 05-11-2008, 07:43 PM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Michael:
Don't know about anyone else but ERA uses a pick-off in the filler neck to vent the tank.
Might give you a place to start.
DonC
Old 05-11-2008, 07:49 PM
Cobra Make, Engine: HI-TECH 289 FIA
Filler neck is always a good option. The higher the better to avoid spillage. Type of connection will depend on the neck construction, metal or rubber. Vent outside the trunk obviously.
If the tank is not installed horizontally, you may have to vent the high point of the tank or it will never fill completely. If this is the case, vent the tank to the filler neck and place an addional vent to the outside higher up on the neck.
Brass fitings can be soldered if you cannot weld. Its just plumbing!
fiaroadster
Old 05-11-2008, 09:50 PM
David Kirkham's Avatar
Original Shelby Owner
We use the filler neck as well.
David
Old 05-12-2008, 01:00 PM
SF_SN888KE's Avatar
Cobra Make, Engine: Cutting Edge Replicas, 427 World block SBF, TWM Injection
Some caps have vents in them, (small single hole? Could always drill more.) I did this, but also vented the tank to the filler neck.
Ron; SF_SN888KE
Cutting Edge Replicas 427
Shell Valley Daytona #27
Old 05-12-2008, 01:12 PM
SF_SN888KE's Avatar
Also, venting the tank (not the filler neck) helps when fueling the tank (venting air out) and prevents 'burping' and gas overflow....
Ron; SF_SN888KE
Old 05-12-2008, 01:23 PM
mickmate's Avatar
It sounds like you are using a pickup at the bottom and the 90 fitting is available. I would plumb that up into the rear inner fender. You might also want to put a rollover/spill valve into the vent plumbing. Like Rick said it's just a little plumbing. You could try what you have and see if it even needs venting. It depends a lot on tank shape, angle, fittings location, cap venting etc. Think like the fuel!
mickmate
http://www.actoncustom.com/
Old 05-12-2008, 04:27 PM
Red face
Thanks to all for the replies,it's my first cobra. I was wondering what was the best technique to plumb a 90 degree fitting from the top of the tank to install a rubber hose all the way up along the filler neck which will be a piece of rubber hose that will connect the cap piece and the tank elbow. I don't know if i can tap fillet in the tank,if there's enough material,would somekind of a bulkhead fitting work if i seal it properly. Somebody suggested soldering the fitting !!
Old 05-12-2008, 04:51 PM
Hmmm, soldering the filler neck of the gas tank. You might just want to farm that out to somebody.... But make sure they have shop insurance before you do.
Old 05-12-2008, 05:42 PM
Don't worry it's bone dry,just got the roller,never had gas in it yet !!!
Old 05-12-2008, 08:44 PM
mickmate's Avatar
A couple of questions, why are you talking about soldering or tapping the tank now? What is the tank made from? Aren't you going to use the existing elbow? What thread type/size is the elbow? Why not hard plumb it instead of rubber? OK a couple is more than 2 for me.........
mickmate
Old 05-13-2008, 06:02 PM
I just want to put a vent to my tank there's none,it's a handmade tank from stainless. I guess i'll put a bulkhead fitting at the top and run a rubber line up along the filler neck with a filter or rollover valve for fumes containment. I wish i could post pictures. Thanks anyway,i know sometimes it's hard to picture what people are talking about. Bye!
Old 05-13-2008, 06:05 PM
Wink
Thanks Don for the drawing i might go with something close to that,i just want the air to get out when i will refuel one day.
Originally Posted by DonC View Post
Michael:
DonC
Old 05-13-2008, 09:56 PM
A roll over valve is designed to stop liquid spills, not vapor. filters will stop particles from entering, but will not stop vapors from leaving. A bulk head fitting designed with a seal would work well. You absolutly need something. Random engine stoppage and a collapsed tank can ruin your day.
Something like this maybe with a nut on the inside
Holley Performance Products -6 AN Male to 1/2"-20 O-ring Port*985065ERL or a
Russell #670850. you can add a AN to pipe adaptor if you want to use plain hose with a barb fitting.
fiaroadster
Old 05-14-2008, 04:57 AM
mickmate's Avatar
Roll over valves shut if they are upside down. They are plumbed into the vent on the tank. I like Jegs comment, "the one part we hope you'll buy and never need to use". JEGS Roll Over Vent Valves - JEGS
mickmate
