Old 05-14-2008, 09:49 PM
Wayne Presley's Avatar
Cobra Make, Engine: FFR 302 stack injected
Send a message via AIM to Wayne Presley
Default Russ' Butler Cobra with FE update
Here's some pics of Russ Richard's Butler cobra that's in the shop right now for a custom fuel injection to replace the 850. Russ is in town and asked me to post some pics. It's a Dove 499ci FE side oiler, with high riser heads, dry sump, billet 3 piece intake manifold, Kirkham billet coolant tank, putting power through a top loader hooked up to a Halibrand quick change rear end.
Wayne Presley
www.verycoolparts.com
Old 05-14-2008, 09:51 PM
Wayne Presley
Old 05-15-2008, 05:48 AM
Default Beautiful machine work
Wayne Presley Russ has a great machinist to make a manifold like that. If you get a couple of pictures for the dry sump setup could you post them. Wissh him LUCK with the Dove motor. Rick L
Old 05-15-2008, 01:04 PM
DonC's Avatar
Sure is purdy. Impressive machine work.
DonC
Old 05-15-2008, 01:37 PM
lovehamr's Avatar
Stolen Avitar
Is he going distributor-less or is the machine work just not done? If he's going w/o a dist. what system is he using?
Steve
Old 05-15-2008, 06:22 PM
SoTxButler's Avatar
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
It is going to be distributorless and I am using an Electromotive TecGT. The coil pacs are mounted on the frame rails under the exhaust manifolds, so the wires will not show. The wires are hooked up to the plugs in these pics.
Russ
Old 05-15-2008, 07:25 PM
Chaplin's Avatar
Very nice!!
Replica is not a dirty word.
Old 05-15-2008, 10:02 PM
More pics. On the dyno tomorrow!!!!
Wayne Presley
Old 05-15-2008, 10:04 PM
Wayne Presley
