November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-21-2008, 07:38 PM
Cobra Make, Engine: Kirkham #570 w Shelby FE
Your wire between the coil and distributor may be broken down internally. (common with carbon core wires)
Cap and rotor normally come as a set. I would check the center contact carbon ball in the cap to make sure it didn't fall out. (again common problem) Your rotor will have a spring loaded contact to the center cap pin, this should contact the cap pin and can be checked by placing a small piece of clay on the contact then install / remove the cap and see if the clay is completely penetrated.
You've got a gap somewhere in the path to the plugs that's large enough to make the jump to the air cleaner an easier route...
