Old 06-22-2008, 04:37 PM
priobe's Avatar
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Where to get Pins for Knock offs
Hi All
I have a couple of questions.
1) I have a set of PS Engineering wheels and would like to get new Pins. I am using a 8.8 independent rear. I pulled off my tire and noticed that the Pins ( threaded lugnuts) are cracked and would ike to get new ones.
2) does anyone have the part number for the hat when using the 2 piece rotor from Wilwood?
3) What is the best way to remove and replace the stud in a wheel hub.
I have always used a lug nut to pull them through but wanted to know if they sold a tool to do it the "rightway"
Thanks
Old 06-22-2008, 07:33 PM
mickmate's Avatar
1 Vintage Wheels Bob and Margot Lacey
2 I've been getting some offset rotor hats from Stock Car Products and making flat ones
3 If you can access the flange they can be removed and installed in a press, using the lug nut to pull them through is fine just make sure they're square and you don't bottom out (bugga up threads). You already know why they have the smaller diameter unthreaded part to get them out with the BFH;-)
mickmate
http://www.actoncustom.com/
