| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
07-06-2008, 10:23 PM
KY
Cobra Make, Engine: B&B, 428 FE, toploader
Fuel pump recommendation
I currently have a blue holley electric fuel pump part#12-802-1 and am thinking about replacing it with the Holley hp series part #hly-12-125 because it is supposed to be better and quietier. Has anyone had experience or thoughts about the hp pump? Thanks, Chas
07-06-2008, 10:24 PM
KY
Sorry about the double post but my computer sent me to lala land and said it didn't go the first time.
07-07-2008, 04:17 AM
TX
Cobra Make, Engine: ERA, Ford 428 SCJ
Unless you are having fuel delivery issues, I wouldn't change.
07-07-2008, 05:24 AM
VT
Cobra Make, Engine: E-M 427 Top Oiler stroked to 482 by KC, Stage 2 heads, a Quikfuel and Voila, 640 hp
I did this exact swap when my blue one died. So far so good after about a year. It's much quieter but it is a little longer so make sure you have room if you go with it.
Tim
At first, nothing happened. Then after a few seconds, nothing continued to happen.
Douglas Adams - Hitchhiker's guide to the Galaxy
07-07-2008, 05:35 AM
NJ
Cobra Make, Engine: B & B
I finally installed a mechanical pump and I am so happy. No more pump noise! I tried 2 different pumps a Holly and a carter both boasting Quiet and they were anything but.
An in the tank pump is quiet, can you make that happen?
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
07-08-2008, 08:34 PM
KY
Thanks everybody for your replies.
Traveller-I am not having problems but I am trying get it quieter
Tim-glad to hear you had a good experience because that convinces me to go that way
Jams-I am looking for an easy fix and the HP pump seems good. I have the standard B&B tank and don't know anything about putting an in tank pump from scratch.
Thanks again, Chas
07-09-2008, 03:27 AM
NJ
I've been through Holley blacks and blues and finally threw them all out and went with an Aeromotive pump and regulator. Never looked back.
Roscoe
Roscoe
07-09-2008, 06:26 AM
fl
On my previous Unique, the electric fuel pump was very loud and it was mounted to the chassis - without a rubber pad between the pump and the chassis. Installing the pad / damper - quieted the pump noise significantly. Rick
07-09-2008, 06:58 AM
CT
Cobra Make, Engine: Performance Cars Venom 427 Keith Craft 408 Stroker
I dont think much about fuel pumps since I ditched my Holley blue for a mechanical. A local builder, Joe Lapine, once told me he would never put an external electric fuel pump in a street rod, race only. I think he was concerned with safety and reliability for the street. If the engine stops, the fuel stops, no manual or pressure switches required. I took his advice and switched to mechanical and it has been a plus. No noise, one less thing to debug.
Aeromotive pumps are supposed to be good, and Barry Grant as well.
If I can see you, I'm too close
07-09-2008, 07:49 AM
NC
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Just installed two Holley red pumps on the GT40. They're mounted to the rear bulkhead, which is directly behind the seats but in the engine compartmet. I used rubber grommets for noise isolation, limiting noise to a reassuring purr. Like to hear the pumps.  However, if they are mounted directly to the body . . . lots of noise.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
