07-23-2008, 09:19 AM
TN
Cobra Make, Engine: Street Beasts- 351 Windsor
Roll Bar Help!
Hi,
First post here so bear with me if its in the wrong forum. I need to replace the rubber grommets around my roll bar and wanted to replace with the alum bezels like the ones that finish line has (BK1)
The only problem is the roll bar does not come out. Is there an alternative to this or possible an open ended style bezel somewhere?? Thx.
07-23-2008, 10:32 AM
You could have them precision cut and then mount joining halves once repolished?
07-23-2008, 11:14 AM
TN
Would a machine shop be able to "splice" the bezel like that. Wondering how i would re-seal the bezels once joined around the bar? some type of epoxy?
07-23-2008, 11:42 AM
az
Cobra Make, Engine: none yet but it will be mostly scratch
Roll bar bezels
Home Depot has some nice chrome pipe bezels that split apart.
I am planning on using them on mine when I build it. Do not laugh, they might look good.Go take a look
tim "FISH" fisher
Tucson,AZ & Kabul,Afaghanistan
07-23-2008, 11:53 AM
TN
Thanks for the info fish, i will head out there now.
07-24-2008, 04:42 PM
TN
Sorry to inform you fish that the open ended flanges from home depot wont work. I would really like to use the ones from finish line. They are nicely done. Just not sure if a machine shop or someone can alter them to get around the roll bar. Surely SOMEONE out there has had to replace your roll bar rubber flanges over time??? Any suggestions would be appreciated!! Thx.
07-24-2008, 06:21 PM
AL
roll bar
why can you not remove the roll bar?
Dwight
07-24-2008, 07:22 PM
Dwight
I agree. I've never seen one that couldn't be removed?
07-24-2008, 08:56 PM
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
They are ALL removable in one way or another, it is just a pain in the a$$ sometimes to do so.
My biggest problem is the carpeting in the trunk that wraps around the lower arm of the roll bar. THAT would be 'messy' to remove and redo!
Glyn
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
07-24-2008, 09:56 PM
California Dreamin Member
Also, check your bar diameter before you order. The 1.5" bezels that FinishLine sells are each perfectly round and would not work with my roll bar, as the rear-most brace enters the car at an angle (as yours does, too I bet) effectively making it an ellipse.
The 2" set they sell has 2 round bezels and one elliptical bezel, which accomodates the entry angle of the rear brace.
07-25-2008, 02:02 PM
TN
You are correct Van that my back part of the roll bar is slanted requiring the BK2 part from finish. As far as the roll bar i have it in the paint shop now(and they are doing a SAWEET job) they said the roll bar was welded to the frame?? There is a cut area at the top of one of the pipes put i could not find another area to be able to "un-cap" the roll bar. I thought about ordering the BK2 and see if i could get a machine shop to get it to work. only solution i have at this point.
I would really like to post a few shots from my cobra on here and have one on my name but im not sure how to get them imported?? Can anyone help me out? Thanks for all yalls help guys.
Wes
07-25-2008, 02:55 PM
posting pics
Wes
I think the easiest way to post pics to cc.com is to get a photobucket account - it's free at www.photobucket.com. After you upload your photos to photobucket, you can just "copy & paste" them into the post field. Copy in photobucket, then paste in clubcobra.
You need to experiment a little to get the size you want, but it's pretty straightforward.
BTW - The 2" trim grommets look way to big for a 1.5" roll bar. If you have a 1.5" bar and find something that fits and looks good, please let me know.
Reason: add info
07-25-2008, 04:41 PM
WOW...I stand corrected. "welded to the frame" indeed! I have seen a number of folks who have done that themselves, especially the 'racing people', but I thought that all the kits came standard with "bolt on" bars.
bummer
Glyn
07-25-2008, 05:11 PM
TN
Well i stopped by the machine shop today and talked to the senior machinist. He thinks he might be able to do the finish line ones. Wish me luck or im out $75.00
Wes
07-25-2008, 05:12 PM
I think Finishline will sell them individually if you contact them, so you might just try with one to see if it works!
Glyn
07-25-2008, 05:52 PM
Roll Bar
Wes
I have a 1.5" diameter bar. We took a close look at grinding one of the the 1.5" rings to fit and decided it would look so bad it would defeat the purpose of using it in the first place. Keep in mind you also have to trim the rubber grommet it sits on.
I then ordered The 2" elliptical trim ring and grommet to see how it would look, and there was just no way - it looked huge around the bar.
Finish Line was very gracious, as always, about accepting them all back as returns.
You may have better luck, or a different opinion. In any case, good luck with it.
05-25-2010, 10:03 PM
Cobra Make, Engine: Johnex EQ
I am having the same problem.
Ed
Johnex EQ 514
05-27-2010, 09:46 PM
GA
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Contact Russ at rtcobra@comcast.net He makes bezels for cobras and may be able to make custom ones exactly to fit your needs.
Anyone with good machine shop skill can make what you need. Just have very accurate drawings for them to use. So mock everything up. Figure out what rubber seals you plan on using, how the seals fit in conjunction with the hole in the body, where the fasteners will go. Try to use nut-serts in the body as your fasteners. But if the holes are too big in the body you may not be able to, etc. etc.
The oval bezel could be a bit more difficult. But with all the CNC machines out there you should be able to meet your objectives.
I plan on machining my own in my shop. but I won't being doing it for a while, so much else to do.
Good luck, Arthur
05-30-2010, 04:19 AM
GA
Cobra Make, Engine: Street Beasts 302 HO
Did you get your roll bars from Street Beasts or somewhere else? I have a Street Beasts Cobra and their roll bars. They have a bolt thru the tubes that can be removed. The rear tube has a bolt at the top and the others, a bolt just above the "anchor point" on the frame. If you have some "home made" or other brand roll bars, this may not help.
Here is a picture that hopefully you can figure out.
52chevyred
