Old 07-26-2008, 09:36 AM
Default 393 stroker
I am thinking about putting a 393 stroker kit in my cobra. Any ideas about how much hp I should gain? Any thoughts on this at all? thanks, Pudge
Old 07-26-2008, 12:22 PM
DAVID GAGNARD's Avatar
You can build a 393 stroker with 300hp to 600+hp,all depends on heads/cam/intake/carb/ignition/headers and a host of other things.....including cubic $$$$$$$$$$..
You need to give more info on what you expect and want you want.....
DAVID GAGNARD
Old 07-26-2008, 12:52 PM
david, i have a 351 windsor 385hp. I am probably going to keep everything the same except the stroker kit.
Old 07-26-2008, 01:56 PM
wtm442's Avatar
Beam Me Up Scottie
450 to 475 HP at the flywheel.
Warren
Old 07-26-2008, 06:41 PM
What Warren said............plus a lot of torque!!!!!!!!!!!!!!!!!!!
DAVID GAGNARD
Old 07-27-2008, 12:24 AM
LMH's Avatar
LMH LMH is offline
It's a great engine choice. Better than 408 in my opinion because of the shorter stroke but still lots of torque.
Old 07-27-2008, 02:55 PM
385 hp / 351 * 392 = 430 hp
If you changed nothing but the stroke, I would estimate 430 hp, and that is assuming that exhaust side and intake side will flow as well at the higher displacement.
Am I looking at this wrong?
Old 07-27-2008, 03:00 PM
392cobra's Avatar
6th Generation Texan
That is what Ford rated my 392 crate engine at,430. Some say they were conservative in their rating.
