Old 09-17-2008, 01:37 AM
Cobra Make, Engine: Unique Autocraft Python
Default Hazard warning wiring
Does anyone have a simple wiring diagram showing how the hazard warning switch is wired. For some reason they only work when I select left or right signals to on??? I'm confused.
Ian
Old 09-17-2008, 03:22 AM
Ron61's Avatar
Question
Ian,
What kind of car and column do you have. Some are different. My 69 Cobra has an extra flasher unit that is just for the hazard signals. My replica had wiring to a different switch on the column.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 09-17-2008, 09:36 AM
Hi Ron,
It's a 92 Python Autocraft. I am not sure where the column is from but it is fairly basic. I have a separate flasher for the signals. It was all working fine up until today. I just need to know the basic wiring diagram so I can trace where the problem is.
Ian
Old 09-17-2008, 11:32 AM
It sounds like you don't have power to the flasher in the 4-way circuit.
Old 09-19-2008, 12:45 PM
Thanks for the replies. Strictlyperson hit the nail on the head. No power to the hazard switch. The terminal from the ignition switch to the fuse box had worked it's way loose.
