Old 09-21-2008, 04:52 AM
Greg Curtis's Avatar
Cobra Make, Engine: spf1266 460,TKO,titanium/black stripes
Default Superformance Ride Height
What are you guys running your ride height at. Mine is at 27" from the center of the fender lip to the ground and she seems to look too high. I'm running Goddyear GTII tires 255-15 and 275-15.
Greg
SPF 1266 460/TKO
1971 Chevelle SS
1967 Pontiac GTO Ram Air
1962 Thunderbird Conv.
1991 Mustang GT Built
Old 09-21-2008, 04:58 AM
Banned
Greg, some guys are running as low as 26.5", but that's probably the lowest you can go and not worry too much about bottoming out. I'm running about 26.75" on all corners and I still have 4.5" of clearance at the oil cooler shroud as well as the bellhousing and oil pan. Never had any issues at that height and the extra 1/4" makes a big difference in the looks department.
Also don't forget that the more you monkey with the coil overs in adjusting ride height, you do/can throw off the weight balance of the car and the alignment, accordingly.
-Dean #747
Old 09-21-2008, 08:27 AM
wtm442's Avatar
Beam Me Up Scottie
I'm at 26.75 inches ... no problems. Probably has sagged a quarter inch in the 17K miles. Dennis Olthoff recommends 27 inches as a minimum.
Warren
Old 09-21-2008, 09:41 AM
Got the Bug's Avatar
I noticed my car was set-up pretty low when I took delivery of it. I never thought about measuring it, but just did.
25.5" Rear
26.5" Front
I've never noticed any problems with car bottoming out or with tire contact.
Doug
Old 09-21-2008, 12:11 PM
Cobra Make, Engine: Superformance #2689 Roush 427R TKO 600
SPF recommends 27" as min. Dennis also states that also!
Old 09-21-2008, 12:21 PM
Tony Aprile's Avatar
Cobra Make, Engine: SPF #1358 Silver/Black stripes 466 2X4
Greg...running the same tires Goodyear 255/275
I lowered mine to a look that I liked....26.25" front and 26 rear. I had also asked Dennis a few years ago he said no more then a inch.
Tony
Old 09-21-2008, 12:45 PM
That is how my car sets also, Dennis set it up, I have never really measured it though, always though it set a little low in the rear but looks good!
Old 09-21-2008, 03:55 PM
Tony
I'm 1/2" lower than Tony's set-up. No issue or problems at 25.5", so what's the downside?
I was planning on waiting until I decided to replace the tires to get a full alignment and 4 corner balance.
Lost a bunch of pics due to a computer crash, but here's a picture on the road.
Doug
Old 09-21-2008, 05:16 PM
I believe Dennis said if it's lowered too much it creats a negative camber condition.
Old 09-21-2008, 07:47 PM
Cobra Make, Engine: SPF 2293, Roush 427R-228
apples to oranges i suspect. 275/60-15 (28" height) vs 295/50-15 (26.6" height) if im not mistaken
Daryl
Old 09-21-2008, 09:20 PM
Daryl,
I think you're right. I'm running the 295/50-15 Avid's on the back, with 255's on the front. Based on that, my ride height may still be a bit low...but it looks good.
Do you have 295's on the back? What is the ride height on your car?
Doug
Old 09-22-2008, 01:21 AM
Thanks guys for your responses. I may monkey with it a little bit at a time until I get the look I want. Got the car in 2002 but only have 6500 miles on it so tires still look great but they are at least 6 yrs. old.
Greg
SPF 1266 460/TKO
1971 Chevelle SS
