Old 10-17-2008, 05:55 PM
Cobra Make, Engine: Kirkham 592
Default Does any one use the quick jacks to lift?
I know they were used in the 60's but how well do they work? The original jack doesn't look like it would be difficult to make
Old 10-17-2008, 06:05 PM
Got the Bug's Avatar
The quickjacks on most (if not all) Cobra replicas are not functional and can't support the weight of the car.
Doug
Old 10-17-2008, 06:20 PM
FUNFER2's Avatar
I did try mine very slowly,...and did not have a problem. I was surprised.
Kevin
Old 10-17-2008, 06:49 PM
If they worked in the 60's why wouldn' they work now? As long as the replicar has the same frame set up.
Old 10-17-2008, 06:53 PM
I know mine wouldnt hold very well. They are just bolted to the fiberglass, not hooked to the frame at all.
Old 10-17-2008, 07:01 PM
mickmate's Avatar
If the car was built like it was in the 60's it would hold them. Most newer versions are a little more portly and a little less structural forward of the frame rails.
mickmate
http://www.actoncustom.com/
Old 10-17-2008, 07:04 PM
Hello,
While I've never seen one bolted to the fiberglass. There are two reasons you wouldn't want to use them. 1. you have a fiberglass body and you don't want to tweak it, 2 your have an aluminum body and you don't want to tweak it. It's two 7 or 8 inch long bolts that will flex!
During racing, they could give a rats ass if they bent the aluminum (and it did) they would just hammer it back into place tomorrow.
Old 10-17-2008, 08:03 PM
Barnsnake's Avatar
I have seen pictures (somewhere on this site I believe) that show an original race car with special reinforcements on the quickjack supports. The body was still bent on the front.
Kevin...... You're a brave man!
Old 10-17-2008, 08:12 PM
Nobody with any sense uses them, they are for looks only. They barely worked on the original cars. I've seen pictures of original cars' jacks all bent up from jacking.
" It ain't no big deal"
Old 10-17-2008, 10:31 PM
Karl Bebout's Avatar
I nerver thought they were good for anything but shin busting.
Karlos
Old 10-18-2008, 05:07 AM
427 S/O's Avatar
I thought about making and using the actual 'jack', I have a pretty good picture of one in use. Then I thought, that jack is huge, where would I store it?. Let that idea go......
Perry
Old 10-18-2008, 06:07 AM
This is the back of the front ERA Quick Jack -- I don't think it would support jacking up the front end. And I don't want to have to ship it back up to Connecticut Custom Car to fix "my finding out."
Old 10-18-2008, 06:13 AM
marcalan's Avatar
Cobra Make, Engine: era 289 FIA #2112
I asked Doug at ERA if I could use the quick jacks on my fia car, and he said not to do it.
live for the moment or it may pass you by
Old 10-18-2008, 06:18 AM
Well I think Fred's got the newest build... maybe we could get him to try?
Old 10-18-2008, 08:12 AM
Madmiles442's Avatar
Really good for a knick in the forehead too...
MadMiles442
Old 10-18-2008, 11:05 AM
on most replicas they are ornamentation only, and NOT functional. SPF owners manual says to not use them as they are cosmetically attached for looks only and not usage . Bill
Old 10-18-2008, 11:50 AM
MaSnaka's Avatar
You can take them off and replace them with bumpers. But then again they are just for looks too.
Old 06-04-2011, 02:53 AM
Dubbs's Avatar
Cobra Make, Engine: Spitting Image Sportscars
Default Functional Quick Jack
Whilst one can't carry this around, it is very useful in the garage, however, with a 'Spreader Bar' and a Race trolly jack it works well anywhere. In fact I can jack the rear or the front, using just one of the 'Quick Jacks'
Old 06-04-2011, 05:18 AM
lovehamr's Avatar
Stolen Avitar
Without some substantial reinforcement on my BDR I wouldn't even try that.
Old 06-04-2011, 05:34 AM
mdross1's Avatar
If had them would use them, my bumperettes are bolted to the frame.But having a floor jack it is still much more convenient to jack off the frame, it always lifts both tires off the ground.If I spent a lot of time racing the car and needed to change rubber in a hurry would have a pit crew knowledgeable in quick jacking car.
