  #21 (permalink)
Old 11-04-2008, 09:31 AM
The crank was brand new..a scat cast crank. that journal will be polished.,..but no marks or scratches...or by feel. Obviously a better inspection once its tore down
The engine ran for all of 45 minutes to maybe 60 minutes top
We did not open the second cap on the same journal...thats happening today
  #22 (permalink)
Old 11-04-2008, 09:38 AM
Rick Parker's Avatar
Just an outside chance but with the 69 block which has a marginally shorter deck height I think there is a specific piston pin height for that engine which is different from the later 351's, check into it. Outside of a twisted rod, be sure the rod cap is installed in the correct orientation and the rod fasteners are retaining their clamping force and have not been overstressed and most importantly that the finished bore of the rod is correct, it must create "Crush" on the bearing shell to keep it captive.
Rick
  #23 (permalink)
Old 11-04-2008, 09:50 AM
A question now about the rod bolts...we have already ordered new eagle connecting rods, why take chances as the last set of stock rods were reconditioned.
We did use the old ARP rod bolts as the engine has only 3800 miles. Whats everyones thought that when the first bearing spun...it maybe streached or tweaked those 2 bolts??
is it common to reuse the old bolts when so few miles are on the engine?
John
  #24 (permalink)
Old 11-04-2008, 09:54 AM
DA...I was just thinking....the rod bolts are studs, and the new rods will come with them
John
  #25 (permalink)
Old 11-04-2008, 10:01 AM
CobraEd's Avatar
If it is a new aftermarket crank, maybe it is not drilled thru from the main to the rod journal. or maybe there is crud in there.
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
  #26 (permalink)
Old 11-04-2008, 10:12 AM
Yes it was a new SCAT crank.....I hoped he would of checked that
thanks
John
  #27 (permalink)
Old 11-04-2008, 10:27 AM
JohnM,
If you get them, pictures please.
f
  #28 (permalink)
Old 11-04-2008, 10:32 AM
Cobra Make, Engine: jbl
.002 on mains and rods is pretty tight from what i've read.
  #29 (permalink)
Old 11-04-2008, 10:37 AM
vector1,
I believe he said the bearing spun out without damaging the journal. How could that happen @ 002? No blueing either.
f
  #30 (permalink)
I will try to get some photos tonight
what does everyone think of those clearances??
John
  #31 (permalink)
Old 11-04-2008, 10:45 AM
CobraEd's Avatar
If it had tight clearences but started knocking right away, I would say that journal had no oil. A tight journal will not knock. Musta been starved for oil. I would absolutely check the hole drilled between the main and the rod to ensure that it is clear all the way thru!!!!!
________
________
  #32 (permalink)
Old 11-04-2008, 10:50 AM
CobraEd,
We will see. That builder is not happy.
f
  #33 (permalink)
Old 11-04-2008, 11:19 AM
CobraEd
not sure until the head is pulled...but I think the knocking was maybe the piston just tapping the head after the bearing moved??
thats what happened last time
with the crank being brand new and all its "surface hardness" being fresh...and the engine ran for no more than 45 minutes. I think thats what saved the crank
the old crank was all chewed up...but it had been ground and I think most of the hardness ground out of it...if that makes sense
John
  #34 (permalink)
Old 11-04-2008, 12:35 PM
The only thing I can think of is that the rod id is elliptical. That would have been checked by the builder as well as twist, etc.
f
  #35 (permalink)
Old 11-04-2008, 11:29 PM
Gaz64's Avatar
Did the engine builder wash the new crank and check for fluid flow through all of the oilways? As others have mentioned, either rubbish in the channel between your failed bigend and the adjacent main that feeds it, or insufficient crush on the bearing.
Did he measure bearing crush? I've dealt with an engine reconditioner that doesn't understand that term.
1 thou per inch of pin diameter is acceptable for bearing clearance.
Gary
  #36 (permalink)
Old 11-05-2008, 11:17 AM
Hello All
Latest update.....I am not sure if this is blowing smoke or for real, but the current therory is a bad crank...its a new crank from SCAT, just a cast model
We originaly wanted a Eagle but couldn't get it in time so went with the SCAT
Anybody know anything about their quality etc on the cast models.
It didn't seem to be an oil supply problem...no discoloration from heat, no turning blue etc....
The builder is eating the crank...maybe it can be warrantied....45-60 minutes on the engine I picked up for the new connecting rods...he's doing all the labor, bearings, gaskets cleaning etc. etc.
I feel he is doing right by me
Any thoughts on the crank...I still think it was the connecting rods
John
  #37 (permalink)
Old 11-05-2008, 11:22 AM
CobraEd's Avatar
OK, . . . . But what about the crank is wrong?
Journal too big?
Journal too small?
Journal not square side to side?
Journal out of round?
Journal stroke longer than the rest?
Oil passage too small?
It is fine to say it is the crank, but you should know WHY it is the crank, or you are shooting in the dark.
Ed
________
________
  #38 (permalink)
Old 11-05-2008, 11:52 AM
so now it is a bad crank. what was it when he did the assembly?
  #39 (permalink)
Old 11-05-2008, 11:58 AM
Jac Mac's Avatar
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
The only thing common to this problem is the block- you have changed crank-pistons-rods etc ,but all still in the same block and the same bearing ( # 3 if I read your posts correctly ) which feeds from the center main bearing. Now you mention that prior to the bearing problem occuring that the car was involved in a minor accident--- could this have hit the crank on the snout & damaged/cracked the center main web to create an internal oil leak and reduce supply to that bearing, remember this is the thrust bearing, any hits etc are felt here---- or is there a end float or spigot brg problem that is causing similar issues. The center ( or Any ) cam bearing can also cause a localised loss of pressure at each main journal if it has delaminated and lost some bearing metal.
Jac Mac
  #40 (permalink)
Old 11-05-2008, 12:45 PM
From my experiences, Scat is better quality than Eagle. I'd rather have a Scat crank.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Display Modes
