  #21 (permalink)
Old 11-22-2008, 06:45 AM
Tom Well
I can change out my pads in 30 minutes as well even with inboard brakes on my CCX. Seems like the XJS might be a nightmare since it is so packed in?
On the serious side, can't you get a good 20,000 miles off of your rear pads? Or maybe half that under track conditions? Rear pad replacement is a once or twice occurrence in the ownership of the car.
  #22 (permalink)
Old 11-22-2008, 10:17 AM
CHANMADD's Avatar
That's what I thought! In fact I have had my car 20 years and 55000 miles and changed pads twice....and the discs once The sideshaft comes off ,,4 nuts a long extension ,an air gun and 1,,2,,3,,. The caliper does take a little effort (this is to change the discs) but..I also used to service Jags and the book does tell you to drop the rear suspension ,but I have done many jags pads including the handbroke pads without removing the whole rear end, its not the simplest job but.......on a Cobra there is a lot more space.
I think the unsprung weight advantage outweighs the servicability of inboard versus outboard brakes. thats a lot of pounds hanging at the end of the axle...
  #23 (permalink)
Old 11-22-2008, 10:27 AM
Not to mention the unsprung weight issue. ERA mounts their custom outboard braked rear in an aluminum sub frame with cast aluminum uprights. There's an overall weight savings of about 50 lbs. over the Jag rear while keeping the unsprung weight pretty much the same. Of all the cool parts on the ERA, the outboard braked rear is, I believe, the coolest.
  #24 (permalink)
Old 11-22-2008, 06:47 PM
HI Doug. ive been thinking of doing the same for a couple of years but due to cost of tanks food i havent. heres an idea ive also wanted to do. look in the era manual i sent you , they sell a removable rear bulk head door just for this reason im sure someone can make it work. call me the next time you are in seattle. Bob
  #25 (permalink)
Old 11-29-2008, 07:00 PM
Hi Doug
Here's some info on the rear brake setup. When using the Wilwood rear mount kit you must make sure there is enough clearance behind the rear, on Contemporaries the tank can be a problem, the emergency brake location can also be a problem with some chassis, Machining is also required on the late diffs 68>. My advice would be to keep the original Girlings and either put the gas slotted rotors on or spend more $ and install the vented Girling conversion. Both of these will be a lot less work than trying to install the wilwoods The Girlings are a bit heavier but in my opinion are a very good caliper and your talking about sprung weight so there may be other locations on the car that you can save weight.
Mike Bontoft
CWI inc
Display Modes
